....This story is leading somewhere....
Rather than set up the degree wheel, dial indicator, etc. I decided to just
guesstimate about 2 degrees advance by loosening the EX. sprocket bolts
and bumping the cam forward. I had looked at enough cam/sprockets to
guess about 2 deg. I wouldn't do this on a customer's bike but I felt like
exploring on my bike.
The first ride was a surprising WOW ! The top end power was back almost as
I had expected and the IN. ports quit coloring like EX. !
However this opened up a lot more questions about cam timing. I decided to
find out what the stock specs for the CB900F were. Surprise ; 102.5 IN. and
107.5 EX' which is very close to what I wound up with. I left the timing where
I had it but I still felt like the motor had more power to be found. As it turned
out the rest was in the jetting, the needle profile. It wanted a far richer needle
but that's another whole story.
Much later when I was given the LC chart, I looked up the 900F starting LC number
and curiously it was105.
I remembered something that the guy said about the "split
lobe center" method and like most all other info, no explanation. I'm not sure how I
arrived at the idea of adding 103 and 105 and diving by 2 =104 but I guessed that must
be it, "split lobe center". I'm still to this day not sure if it is but I learned something
about using the chart. Stock CB900F ideal starting point is 105. 102.5 +107.5 = 210
divide by 2 = 105, start. point !
Now I'm getting somewhere with how this chart works
BUT...what is "Ideal" about the starting point number ? I could only assume that it was a no.
arrived at by the engineers and much dyno research and beyond my capabilities to grasp.
Thus the saying "the more you learn, the more questions there are"... something like that.
Why the staggered numbers from the Ideal starting point ?
I come seeking the magic numbers, your Sageness.
"But, my child, there are no magic numbers"
