hey guys
i'm back at it, actually never stopped just haven't had much chance to post anything. well, the BIG DAY happened last week-end. i actually got out on this thing for the first time ever, actually first time ever on a cbx! what a blast although i never really got it above 50mph on my little street. i have no insurance or headlight for that matter but i wanted to get it to a point where i could go around the neighborhood to make sure i had at least some sort of a reasonable roller. i am happy with the machine so far, seems to shift nice, brakes work awesome etc. but i have a couple questions/ideas i would like to run by you pros. these are my thoughts or questions in no particular order. on first couple passes the engine seemed to smoke a little but seemed to get better and better. valve train is not i would say "noisy" but you can tell it's there, i think this is a common situation for a bike with 24 shim in buckets and 4 cams etc. keeping in mind i have logged 7 whole miles to date. my thoughts are that i will run it down to my local shop where the owner is an ex honda racer and loves cbx's. i would like them to adjust my pilot screws, sync the carbs and adjust the timing chains (i can do the chains but reaching that rear nut is a pain in the butt). i think i should log a hundred miles or two and THEN go into the valve train and check/adjust shims. make sense? as far as the carbs go they seem to be working spot on so far, again need to log some miles to really find out but on first ride they seem to work great. my rear shock low pressure light has a tendency to go on and off at times however when i check the pressure it is fine so i guess that is what we call an "idiot light". anybody have any idea on what could cause this or how to resolve it? electrical is all in or on the bike, restored my signal lights with the SEM trim paint, LOVE THAT STUFF and all new lenses, look awesome. had my front forks rebuilt at dealer and they're holding air (at 10lbs right now). i was going to go naked on this but after some thought and fooling around with the suzi headlight decided against it. my painter now has my fairing and related parts and he is going to paint those now as well. here is 2 fairing related questions. i have the fairing support on the bike now so i could make sure everything fit up o.k. after powder coating. has anyone tried or is it even possible to mount the skins to the support structure while it's mounted on the bike? obviously you probably should assemble it all off the bike but then you have to manouver this whole part onto the frame now WITHOUT scratching anything, just a thought. also, regarding the part of the support structure that thru-bolts at the head tube. the manual is a little un-clear to me. either the wiring harness or the throttle/choke and clutch cables go "inside" the "U" portion of this piece, sort of between the head tube and the fairing frame. can anyone confirm which it is? right now i have all the cables inside and the harness outside but i THINK maybe it should be the other way around, cables on the outside harness on the inside, your thoughts? well congatulations if you managed to stay with this post this long, i won't ramble anymore. i hope i have phrased my thoughts/questions in an understandable matter that you can offer any feedback. here is just one shot of the fresh paint. i know you all love pics and i will post some more when they are worthy.
thanks a lot!
kent
