Misfire & Hesitation
Kool_Biker
Re: Misfire & Hesitation
Post by Kool_Biker »
Jeff Bennetts wrote:I also made a cheapo sonic cleaner for about $12.00 that works great at cleaning the carbs internally and externally while using the hot soapy water. The reason the hot soapy cleaning is necessary is because sometimes calcium deposits will plug the carbs from water being in the fuel system and petroleum based solvents will not dissolve them.
Heres a pic of the sonic tub
Hi Jeff, any chance we could have some info on how you constructed your sonic cleaner? Few more photos too?
Would be very helpful, I am sure, for lots of us!
Aris
Aris Hadjiaslanis
ICOA # 6309
Berkshire, Windsor
The componets consist of a Rubber Maid container just big enough to contain a set of cars, a cheapo Harbor Freight palm sander I bought new for $9.00 and a rheostat (light dimmer switch) I had laying around to control the ocillation.
The sander was mounted to the side of the tub by removing the screws that hold the pad of the sander to the sander body, I put a small piece of 3/4 oak I had laying around on the inside of the tub serving as a backing plate then fastened it through the tub into the sander pad through to the sander body by using longer screws.
oilheadron
Post by oilheadron »
"This could be a toughie."
Just wanted to reiterate my initial impression. :)
It's probably going to be real obscure carb clog somewhere like Bob said earlier.
SteveG
Post by SteveG »
Jeff Bennetts wrote: The componets consist of a Rubber Maid container just big enough to contain a set of cars, a cheapo Harbor Freight palm sander I bought new for $9.00 and a rheostat (light dimmer switch) I had laying around to control the ocillation.
I copied Jeff's cleaner and made my own. This is it in action. Works great. Click on the pic and watch it go. :D
Steve
Kool_Biker
This is a very - very useful and may be should start a new thread?
The sonic cleaners which are available commercially, I thought, use supersonic frequencies (around 40 KHz ?).
There is solid theory behind their operation and the way deep cleaning is achieved by way of generating and then the energy released by collapsing micro bubbles combined with the chemicals used.
The systems presented here are seemingly subsonic but I guess quite effective too?
Is it the same principle, or do they simply agitate the hot soapy solution to achieve deep cleaning?
I am tempted to build one. After all, this is at least one order of magnitude cheaper :D
Aris
Aris Hadjiaslanis
ICOA # 6309
Berkshire, Windsor
SteveG
Post by SteveG »
Kool_Biker wrote:This is a very - very useful and may be should start a new thread?
Aris
Aris,
You are correct that these cleaners simply agitate the hot soapy solution or whatever other solution you are using to achieve deep cleaning.
No high tech collapsing bubbles here.
Steve
ajs350
Post by ajs350 »
So with new idle jets and a second carb clean I still have the same symptoms. Misfire and hesitation up to 4K at a steady throttle. So now I'm wondering if this problem is electrical. The bike did this when I bought it and since then I have replaced the plug wires and caps, the pulsar and one of the coils due to one being cracked. With no change in symptoms I have to assume the problem lies elsewhere. Any suggestions much appreciated. Thanks Ross
oilheadron
Have you checked the timing?? I don't remember seeing that mentioned in the earlier posts. If the timing is too far advanced it might have symtoms like you have.
Also, is the misfiring very jolting (like 3 cylinders at once) or subtle like a single cylinder is misfiring (especially subtle in a 6 of course).
ajs350
Post by ajs350 »
oilheadron wrote:Have you checked the timing?? I don't remember seeing that mentioned in the earlier posts. If the timing is too far advanced it might have symtoms like you have.
Ron
I checked and set the timing using the static method from the manual. The misfiring is subtle. With a steady throttle below 4K I can feel the misses and the bike hunts as the cylinder kicks in. At higher rpm the missing is still there but faint. Of course when I open the throttle and accelerate hard the bike runs like a champ, strong and smooth all the way to the red line.
ajs350
Post by ajs350 »
I've finally got my 80 running right! :D :D
When I bought it 5 months ago it would hesitate and misfire from idle to 4K which I figured was either carbs or electrical. The wise ones on the forum told me it was carbs but with past experience in wrenching limited to old brit bikes the thought of tilting an engine and dealing with 6 carbs was a bit intimidating to say the least. So with that in mind I tackled the easy stuff first. I replaced the pulsar as one of the elctrodes had worn down to the block. Replaced plug caps and wires as 2 of the old ones would shock me if I touched them when wet. Replaced a cracked coil and replaced my K&N air filter with a paper one. I adjusted the valves and made sure the compression was equel across all 6 cylinders. Result, no change.
So with the manual out I set about tilting the engine and removing the carbs. First time took me 6 hours :shock: (Having done this 7 times now I can have the carbs on the bench in 44 minutes. Whats your personal best? :) )
I had bought Mike Nixons carb book which really steps you through the whole cleaning process which I followed to the "T" or so I thought. Put the carbs back on and while it was better it was still not right. Took them off, cleaned again and removed idle jets but still no joy. Did it one more time and replaced idle jets, still the same. :cry:
At this point I had a 3 month e-mail thread going with Mike Nixon and had also begun talking with Dave McMunn by phone. If this was not enough help on my way down to Daytona I stopped off to see Louis and he introduced me to Preston Marks who was good enough to give me a carb lesson in his work shop.
I was beginning to think I might not have set my float levels correctly. Off with the carbs again.
Here's the punch line:
The hesitation was due to only 3 accelerator jets working. While I shot carb cleaner through them just like it says in Mikes book they somehow got blocked again so when I snapped the throttle I only got half the cylinders sucking in the extra fuel.
The misfire was because I had the float levels too low creating a lean condition. I was not aware of the compressable plunger at the top of the float needle so when I set the float level to 15.5mm I was partially compressing the plunger. Of course when I removed the float level tool the plunger pushed the float down into a low position. OK for the main jet but too low for the idle jet to get a good flow.
Here's a picture of #6 float incorrectly set. Look at the angle of the float tab and how it is compressing the plunger.
4510
This is a picture of the float needles with the plunger being that little pin at the top. The needle on the left is aftermarket the one on the right an original Honda.
4511
This is a float correctly set with the float tab just touching the plunger.
4512
As per Mike Nixon's book measure with the carbs the right way up.
4513
Check the carbs for leaks. Hook up to your tank and blow into the long tube that comes off the vacuum valve to let the fuel flow. Do this before putting the carbs back on the bike or you will have to take them off again...........been there done that.
4514
Once I had the float levels right there was an instant transformation. It started good and ran smooth to the red line. The misfire was 90% better but I could still feel a little. Dave suggested checking the fuel level using a tube attached to the drain bowl.
Here's a picture of of the fuel level just at the top of the right most screw that attaches the carb to the frame. 1, 2, 3, 5 & 6 were all the same.
4526
This the level of #4 which was below the screw.
4527
So off with the bowl and a little tweak and it was at the same level.
Last thing I did was sync the carbs again. Previously I had removed the gauge faces and with the adjustment screw set all the needles to the same dial position. With the bike idling I adjusted the carbs all to the same level but found if I switched vacuum tubes the readings would change. Having the needles all point to the same number does not mean they are baselined. The way I did it was to attach one of the vacuum tube extensions to #6 carb and attach each guage in turn adjusting the needle to point to the same place. This way you know every gauge is reading the same at a given vacuum.
During this process Dave was kind enough to lend me a set of carbs to compare. This helped no end as I was able to put them on and see how my bike was supposed to run. When I made a change to my carbs I could run them and if they did not seem quite right I could quickly replace them with Daves to confirm.
Early on I found #2 was running hotter at the header than the other 5 by 30F. Today it only runs 20F hotter. Mike told me that you get variations like this and by trying Dave's carbs nothing changed so he was right.
Thanks to all of you who have posted suggestions on this and my other threads. I would not have figured this out without all of the help you have given. Special thanks to Mike, Dave and Preston who shared their knowledge and kept up with my never ending questions.
Ross
Kool_Biker
Very well done Ross, and even better for taking the trouble to produce such a great summary.
You have certainly given me some food for thought :!: ...
Aris
Aris Hadjiaslanis
ICOA # 6309
Berkshire, Windsor
Kool_Biker
Having just completed a re-examination of my 1979 CBX carbs (don't ask), cleaning everything, checking / adjusting float levels, it was very satisfying and reassuring in the end, to physically examine float chamber fuel levels on all six carbs using the 'overflow tube method' already described in this thread (thank you guys).
It is dead easy to do (assuming you have several fire extinguishers around :D ) and gets rid of all the mystique of getting all 6 floats dead right.
Clearly this test will not tell you if you are spot on the 15.5 mm. But it WILL tell you if all your floats are on exactly the same height.
Now if I were to do it again (heaven forbid), I would cut the pipes shown longer, and spend a bit of time before hand, to mount them all 6, side by side, so as to view simultaneously. For this time I had to move the little tubes around comparing their levels with a reference line on the rack.
Prior to all this, it is paramount that the entire rack is transversely horizontal!
Cheers, Aris
Aris Hadjiaslanis
ICOA # 6309
Berkshire, Windsor
markdam
Post by markdam »
Aris
I like the "gun idea" too effective method i almost used the last time i had my carbs off!!!!!!!!!!
