Upgraded Cam Holder Bolts for CBX and 4 cyl dohc
Companies or individuals that provide parts/accessories/services for our CBXs.
CBX-tras
Re: Upgraded Cam Holder Bolts for CBX and 4 cyl dohc
Post by CBX-tras »
FYI, when using the 12.9 grade bolts, be aware that there might be interference with the valve cover due to the socket head and washer, being taller than the stock flange head, hex bolts.
This can prevent proper crush to the gasket and cause oil leaks.
Photo below of where you need to look marked in red. Do a test fit WITHOUT the gasket of the valve cover. if it "rocks" and doesn't sit flat to the cylinder head flange then, you have an issue that needs to be addressed.
genesound
Post by genesound »
Since somebody here in their infinite wisdom has removed my ability to edit my own for sale listings, I can't change it, adjust the prices, or even declare I'm out of parts and not doing this anymore, certainly at a loss as it's been for a while. If someone sends me money I guess I should just keep it? No, I have more scruples than that, I'll refund it of course, but I'm done. Don't send me any money.
And thanks to all of those that bought these and used them over the years. I just sold the last 2 sets to a guy from here a few weeks ago.
Good luck everybody.
And BTW JR, I sold lots of these to people with CBXs and I-4s, and nobody ever reported any issues with the valve cover hitting the bolts. What a disingenuous and basically dishonest fool. You've been a pain in my ass for years. You'll get yours one day.
Thanks for the memories Gene, I have bought a few sets of your viton valve stem seals over the years, thanks and good luck!
Jeff
Gene, yes, I limited the ability to edit old posts, because for reasons I’ll never understand, a few users went back and deleted their posts and made a mess out of a lot of informative threads. My doing. If you want specific edits on the post, copy the text, edit, repost it here in thread and I will transfer the updated text to the first post and delete the holder post.
