PRIMARY SHAFT - INCORRECT POSITION
Re: PRIMARY SHAFT - INCORRECT POSITION
Nice job Mark, and well done.
pietspoed
Post by pietspoed »
Good morning, I'm busy with a customer's CBX1000 - Vin # SC002302891 / engine # SC03E2305771. I've rebuilt the motor and would appreciate advise regarding assembling the primary shaft in the correct position. I understand the description according to the factory manual regarding the older engine using the primary shaft with the spring against the primary driven sprocket / ring nut. However, this engine uses the later shaft without the SPRING. I believe there's a different way to assemble the later shaft. Would appreciate some sound advise.
The Pro-Link shop manual shows clearly how to install the later primary shaft. You need a stout spanner for the ring nut.
CBX-tras
Post by CBX-tras »
And it's left hand thread.
Should you need any shop manual help, here's a link: www.cbxclub.com/manuals
