V12 CBX engine
A good look at the lubrication diagram would probably be helpful. I believe the alternator oil supply, for example is not part of the high pressure side of the oil flow. The oil pressure in the engine builds through defined orifices and areas, such as the crank and rod bearings where the pressure is required to provide the bearing effect.
alimey4u2
ICOA Web Video Director
Post by alimey4u2 »
cbxtacy wrote: He figures the oil is for the clutch driving the CBX alternater and won't be needed. That will help flow/pressure to other areas hopefully.
That's on the secondary pump George which supplies the cooler & the transmission only, however I'm sure Andreas has thought this out well... 8)
silversurfer1050
Post by silversurfer1050 »
Two pumps = two rivers as long as the lake is deep enough (extra sump) Each river carries the same amount as a stock engine...
No?
You will note that I'm posting this late on a "school night". Crown Royal is working its way into my veins as I type. I have a large herd of angst which needs to be drowned before I go to bed. 112:35pm 11/5/2008.
... :oops:
alimey4u2
Post by alimey4u2 »
You bring up some good points Bill.... "Ideally" you would require a larger sump together with increased cooling capacity. I think Andreas "initially" will nurse this engine, after all it's almost 200bhp. As long as there is enough capacity to ensure design pressure is achieved, with all components well lubricated, fatal damage will not occur....
I stayed up late until Ohio was called, bit tired now... :?
cbxtacy
Post by cbxtacy »
Deep sump with two large stacked plate coolers. 6+ quarts. Oil pickup is extended down into the oil.
YOU'RE THE ONE
alimey4u2
Post by alimey4u2 »
cbxtacy wrote:Deep sump with two large stacked plate coolers. 6+ quarts. Oil pickup is extended down into the oil.
:bow: :bow: :bow:
cbxtacy
Post by cbxtacy »
and here's a few more photo's to intrigue you. The first is an old photo with the engine installed. It was before he did all the internal work on the engine.What looks like a radiator is a vertical mounted oil cooler. There's a matching one on the other side. It has 3 ea two barrel side draft Weber dcoe45's on it. The forks fit between the velocity stacks, real close.
2974
2973
YOU'RE THE ONE
Let's see, I ran 2 double 45 Webers on my BMW race car. It had a 4 -cyl, 2 liter engine putting out 160hp. Here the 3 Webers are feeding 12 cylinders, means one 45 Weber for 4 cylinders displacing 700cc. Interesting comparison.
cbxtacy
Post by cbxtacy »
But if I had to pick one of his bikes to ride down to the corner grocery for a pack of smokes, I would pick this one:
2976
even though I feel the V12 is the most awesome looking piece of art, there's just something about this one. It's sooooo functional (for a 2000cc V6 powered bike with a blower on it). And I think the cam belt guards are sexy.
YOU'RE THE ONE
Yes, O.K., but you don't smoke........
Oh, and btw, here are the parts of the oil pump. As you can see, a change in either sprocket would change the pump speed and thus the flow.
Sorry for the small picture. Probably the wrong camera setting
2977
cbxtacy
Post by cbxtacy »
something to consider in the future. Here's the sump Andreas is going to use
2978
and here are the oil lines to the heads
2979
and here's under the engine where he's considering another oil return line from the front head
2980
YOU'RE THE ONE
cbxtacy
Post by cbxtacy »
YOU'RE THE ONE
Terry
Post by Terry »
Remarkable! Its good that he isn't losing interest in it.
cbxtacy
Post by cbxtacy »
I know. In Dec he wants to ride to South America on his KLR650. He's hoping to get it running by then.
YOU'RE THE ONE
