Oh, yeah, for everybody that may be following this topic (we're discussing a COMMON problem here), I would HIGHLY RECOMMEND that you do the following:
Go to your local Home Depot and go to the electrical section. Buy a small box of spade connections, both male and female. To be sure you have the right size, check the WIDTH of the male spade; it should be 1/4" wide. This is the size that will fit INSIDE the female alternator plug. The box should say 'for wire size 14-16'. Pick up about 1-2' of #14 SOLID wire (color doesn't matter). They may give you some flack about such a small length but you're the customer and that's all you need. If you don't have a 'crimping' tool, buy one (you can use pliers/cutters but it's chancy); they're cheap.
When you get home, strip the insulation off of the solid wire. Cut about a dozen (12) 1 to 1-1/2" pieces of bare copper wire. Put a piece of wire into a spade and crimp it tight!!! Do 6 males and 6 females.
Now you have a really good connection into the plugs that come from the alternator and RR. I found that trying to poke around with pointed probes of the meter just didn't cut it and I needed 4 hands to hold it all together. With these copper 'pigtails', you have a GOOD CONNECTION into the plug and a nice place to clip you meter leads to.
I know, I know, what a hassle but, trust me, it will pay off in the long run. You'll have these little test leads to check anytime you have a problem and can run down trouble fast. Further, you will be able to determine how tight the connectors INSIDE the plug are (the females sometimes loose their 'grip' - no jokes here, please). If the male pushes into a 'tight' fit, the connection is good. Using the female spades on the male RR pins is also much more easy than trying to fiddle around with just the meter leads. Just be careful with the female spades so they don't touch each other.
Another note while I'm typing away.
The regulator monitors the 'charging voltage' on the 'BK' (Black) wire, NOT the R/W lead going up to the start relay (battery). This BK lead comes from the main ignition switch on the front dash. So if you have a bad switch base or bad connection way up there, the regulator could see a 'flickering' voltage and kind of go crazy - anything from overcharging to shutting down. So check those connections on the ignition switch and the contacts inside.
Second note:
If you look at the wiring diagram closely, you'll see that the output of the alternator (R/W lead) goes to the downside of the 30A fuse. That means that, if your alternator runs away, there is no fuse protection to the wiring harness, only to the battery. Interesting, no?
More later as I discover.
