Sounds like a good job done, thanks for the info.......BayArchitect wrote:I drilled out the upper tree and installed 8mm SS socket head cap screws. They look great, but more important, I believe no safety was compromised. The holes are already practically the same size as the 8mm bolts. Just the slightest (SLIGHTEST) enlargement makes it work. Don't do this with a hand-drill. Alignment is critical, because you don't want to remove ANY more material than absolutely necessary. Use a good drill press or lathe. Also, I recommend Bostik Never-Seez Pure Nickel Special on all SS threads. I use small foam-tipped disposable applicators (the kind with the wood stick), sold by Griots Garage, et al.
