New Member from Texas (former Germany)
oroepke
Re: New Member from Texas (former Germany)
Post by oroepke »
I have sourced almost all parts of the airbox, I still need the holder for the filter element (I think) and maybe a clamp to hold everything in place. Unfortunately I don't have the original needles and main jets. I have 130 main's in there now! Idle jets are #35.
Anyways, I am not going to mess with the current setup very much, in a few weeks I plan to put the airbox in. In the meantime, I just want to see if the bike needs anything else.
What's a good source to buy original needles and jets? Thanks!
New 1980 CBX owner as of January 2023!
Other bikes: BMW R1200GS, BMW R80 G/S, BMW R75/5
Previous bikes: Several SOHC Hondas and KZ's, a few BMWs, Honda CT, HD Fatboy, XL 500, DR 750, RD 350, CB250....
You can get original Keihin Jets from Kurt here, stock ones for the '80 (VB62) carbs are 110. You'll look a long time for original needles. You need 55A needles. You can't buy them new, just hope someone here might have a spare set. I hang onto all of mine for carb rebuilds. You'll have to go aftermarket, but you'll likely need to buy complete Keyster kits or similar to get them. Don't do that, I have a million of them from back in the day.
oroepke
Post by oroepke »
Can you tell from this picture what the needles are that I currently have in here? Diameter at top is 2.4 mm, at bottom 1.35 mm and the taper starts about 27 mm from the top.
Those are Dyno-Jet adjustable needles, likely stage 3 by the looks of the taper. They will not work in any fashion with the stock airbox. The factory needles are not adjustable, just a solid needle.
oroepke
Post by oroepke »
Ok, thanks. What about the needles from this set? Any opinion on those? Are they any good?
https://www.ebay.com/itm/183567748590?
The ad says '79-'80. Run from that one. The '79 needles are not the same as the '80-'82. If you can't find original needles, I have lots of aftermarket ones.
daves79x wrote: Wed Feb 22, 2023 2:47 pm Those are Dyno-Jet adjustable needles, likely stage 3 by the looks of the taper. They will not work in any fashion with the stock airbox. The factory needles are not adjustable, just a solid needle.
Just to add something to what Dave has mentioned, Dyno Jet stage 3 needles only flow correctly when you use Dyno jet jets, Keihin jets of the same size will flow differently.
oroepke
Post by oroepke »
I think I have the Dynojet jets installed, they have the same silverish color as the needles.
Ideally I want to find all original Keihin needles, needle jets and main jets and go back to all stock.
oroepke
Post by oroepke »
I just decided to raise the needles 2 clicks and see if that makes a difference until I install the air box.
I used this “technique” to install the carbs. Don’t worry, I didn’t force them in, just held them in place, wiggled a bit tighten the strap a bit more, they went in super easy, I was surprised!
You didn't need to remove the carbs to change the needle settings. All the tops will come off in place if you do a bit of wiggling. One notch at a time may have been better - two notches is quite a big difference.
oroepke
Post by oroepke »
I tried to remove them with the carbs in place but didn’t think that would work, at least not with my clumsy hands…
You seem to be right on the 2 notches. Plugs looked a bit too lean before I change the needle settings, now they look way too rich and it didn’t do anything to cure my 5-7k flat spot. But I only rode it for 5 miles like this, will put a few more miles on this weekend.
