Repro Wiring Harness Experience
Re: Repro Wiring Harness Experience
Good and interesting feedback. Thanks.
divan
Post by divan »
Probably nobody would notice, but I want to correct a typo I made at the start of this post. Regarding the repro harness, I wrote: "I measured [the red] wire at 1.14mm, [diameter] though probably this could be 1.50mm, which would make this wire closer to 17 gauge. "1.50mm" should have read "1.150mm". A 1.50 mm cable would be closer to 12 gauge - Ha. Not likely here.
sisxiny0da -- I agree with you; good crimps make soldering unnecessary.
Dick Sullivan
I did just edit the post using my admin privileges, (as the author you can too, by the way), please review and see that I did it correctly, and change it if I didn’t. Use the pencil button upper right in the post.
herdygerdy
Post by herdygerdy »
Great post Divan, very interesting and thank you for sharing your vast knowledge on this topic. I'm sure we are all very grateful for your contribution.
divan
Post by divan »
Thank you, Nils. Didn't know I could edit it myself. Your edit is what it should read.
Dick Sullivan
divan
Post by divan »
herdygerdy -- well, not so vast; I try to share the bits I have some understanding of, since I've learned so much about this bike from this forum over many years, including some of your posts. I'd say the collective knowledge of the CBX here is indeed vast, Thanks to all who contribute. Sincerely.
Dick Sullivan
