How much is too much
Re: How much is too much
This is quite an interesting theory and probably holds some truth, especially for racing applications. But the main reason for setting the clearances on the "wide" side is that the valve will "move" itself into the seat with time and such create a tighter clearance which could cause problems, especially if they are set on the very low end of the tolerances.
- portalespeanut
Perhaps Mike Nixon might chime in on this, but staying on the loose side of spec will also help compression. See his very good website - 'the motorcycle project'.
You begin cutting your wisdom teeth the first time you bite off more than you can chew...
