A garage find close to home
ICOA Rally Director
ICOA Rally Director
Re: A garage find close to home
All pics are correctly oriented on my eye-pad. Electrons do funny things.....
Rick Pope wrote:All pics are correctly oriented on my eye-pad. Electrons do funny things.....
Electrons are funny that way! :D
Irishman1
Post by Irishman1 »
EMS wrote:
steve murdoch icoa #5322 wrote:On my laptop all the pics need to be rotated clockwise 90 degrees except for the last one.
The photo of your bikes lined up shows correctly.
Here too. I am not on a laptop. Regular pc.
Thanks for the info. I don’t know what I can do though, I’ve only used my iPhone and iPad for posting for the past 8 years so no lap top. Of course everything looks correct as I post, pictures are orientated correctly on the camera, then as I post them they look correct and as I look at them on every device.... and on the face book pages,,, weird
ICOA # 6786
Bike in the garage right now:
1979 CBX1000 red
1980 CBX1000 red
1981 CBX1000 prolink
1975 gl1000 blue
1975 gl1000 red
1975 gl1000 sulfur yellow
1975 gl1000 red
1976 gl1000 sulfur yellow
1977 gl1000 black
1977 gl1000 blue
1977 gl1000 black
1978 cb750f super sport
1979 cb750f super sport
It is not a big deal to me.
Don't see it often on this site but the pics that OVER-sized can sometimes be a pain.
Irishman1
Post by Irishman1 »
More progress, disassembled the alternator and found the clutch disc ruined with only 6,000 miles. Looks like something was inside the housing and ground the groves in them, no other problems with it. Good output. Replaced with newly ground discs. Cleaned and painted the housing. cleaned and reassembled the shocks, applied new shock decals,,,my home made shock compressor broke after many shock spring removal and installations though, back to the hardware store for new turnbuckles
ICOA # 6786
1979 CBX1000 red
1980 CBX1000 red
1975 gl1000 blue
1975 gl1000 red
1975 gl1000 red
1977 gl1000 black
1977 gl1000 blue
1977 gl1000 black
That is a nifty spring compressor, Macguyver.
Irishman1
Post by Irishman1 »
steve murdoch icoa #5322 wrote:That is a nifty spring compressor, Macguyver.
:D
ICOA # 6786
1979 CBX1000 red
1980 CBX1000 red
1975 gl1000 blue
1975 gl1000 red
1975 gl1000 red
1977 gl1000 black
1977 gl1000 blue
1977 gl1000 black
ICOA Rally Director
ICOA Rally Director
Looking at those alternator clutch plates, my guess is you have a bearing dragging. Spin the alternator by hand. Any noise or roughness? if so, even a little, replace the bearings. It's easy and cheap. Bearings can be sourced at any decent auto parts store, and are 6201 and 6203 sizes.
Agree, Rick. Those plates aren't the worst I've seen, by far. They are not blue from overheating. But I would certainly replace the bearings and seal and carefully measure the spring for sag and shim appropriately.
Irishman1
Post by Irishman1 »
Rick Pope wrote:Looking at those alternator clutch plates, my guess is you have a bearing dragging. Spin the alternator by hand. Any noise or roughness? if so, even a little, replace the bearings. It's easy and cheap. Bearings can be sourced at any decent auto parts store, and are 6201 and 6203 sizes.
I’m waiting at this moment for a replacement bearing and oil seal to come in the mail!
ICOA # 6786
1979 CBX1000 red
1980 CBX1000 red
1975 gl1000 blue
1975 gl1000 red
1975 gl1000 red
1977 gl1000 black
1977 gl1000 blue
1977 gl1000 black
Irishman1
Post by Irishman1 »
I also have a new spring and both small shims for the B plate and large for the A
ICOA # 6786
1979 CBX1000 red
1980 CBX1000 red
1975 gl1000 blue
1975 gl1000 red
1975 gl1000 red
1977 gl1000 black
1977 gl1000 blue
1977 gl1000 black
A bit confused - first, there are two bearings you need to replace, not just one. Second, you mention shims on both A and B plates? The drive plate, splined to the primary shaft should have a thick fiber washer and a thinner steel one. That is the stock set-up. You would add another steel washer for additional shimming needs (sacked spring, worn plates). There are no shims on the driven plate, just the washer and holding nut. Unless I'm missing something in what you're saying.
Irishman1
Post by Irishman1 »
Working with nils menton on shimming both plates evenly, with a small diameter washer on the shoulder behind the flat plate and the normal large diameter washer on the typical shaft. I have already replaced the shaft end bearing in the outer cover and I’m waiting for the 1st bearing under the three screw retainer behind the oil seal.
ICOA # 6786
1979 CBX1000 red
1980 CBX1000 red
1975 gl1000 blue
1975 gl1000 red
1975 gl1000 red
1977 gl1000 black
1977 gl1000 blue
1977 gl1000 black
I'll not argue with Nils on that one, but can't for the life of me figure out why you'd want to try to shim the driven plate. The exact place in the housing where the two plates meet is immaterial. Shimming just the drive plate is straightforward and quite acceptable.
Irishman1
Post by Irishman1 »
daves79x wrote:I'll not argue with Nils on that one, but can't for the life of me figure out why you'd want to try to shim the driven plate. The exact place in the housing where the two plates meet is immaterial. Shimming just the drive plate is straightforward and quite acceptable.
yeah, agreed but nils has spent a lot of time on this and if it will help him out I’ll give it a go. Easy to remove!
ICOA # 6786
1979 CBX1000 red
1980 CBX1000 red
1975 gl1000 blue
1975 gl1000 red
1975 gl1000 red
1977 gl1000 black
1977 gl1000 blue
1977 gl1000 black
