Re: Sprocket Sizes
Posted: Sun Dec 27, 2015 2:32 pm
Done some reading..the original tyre was a 130/90. I think a 30 profile difference could explain the higher revs..or what you guys think?
Dedicated to the enjoyment and preservation of the 6-Cylinder Honda CBX-1000 Motorcycle. Huge technical library!
https://cbxpress.com/forum/
Well that was actually what I had in my mind but waited until someone more knowledgeable than myself spoke up...EMS wrote:Guys!!!! Motorcycle basics! The 60 aspect ratio on the 160 makes that tire about 18% smaller in diameter than the 130/90. That will produce over 1000 rpm at 6000 rpm
mcferreira100 wrote:Its a Bridgestone Battlax 160/60 ZR18 M/C
Well, sorta. It makes the sidewall smaller, but it's still on an 18" rim. If the tire had an aspect ratio of zero, it still wouldn't be 18% less circumference.cbx1956 wrote:Well that was actually what I had in my mind but waited until someone more knowledgeable than myself spoke up...EMS wrote:Guys!!!! Motorcycle basics! The 60 aspect ratio on the 160 makes that tire about 18% smaller in diameter than the 130/90. That will produce over 1000 rpm at 6000 rpm
Thanks Mike, for doing the math. When I responded this morning, I was only half way through my first cup of coffee, so I wasn't going to attempt any calculations.EMS wrote:You are absolutely, right, Rick.Rick Pope wrote:
Well, sorta. It makes the sidewall smaller, but it's still on an 18" rim. If the tire had an aspect ratio of zero, it still wouldn't be 18% less circumference.The 18% refers only to the sidewall. The total tire diameter difference is a tad less than 6%. The rpm effect at 6,000 is only 360 rpm.
