CBX Racing
- Amazing Poster
Re: CBX Racing
After listening to an interview with Crighton it sounds less like him choosing the rotary than the other way around with the rotary choosing him when as a bike retailer and racer, he became involved with the Norton rotary project. It seems that his eye as a salesman is at least as significant as his engineering interest.
From there it seems to have developed into what we see today. The full story is on the Crighton website and You Tube.
My own taste in exotica tends more towards the Bimota Tesi but there have been some very ordinary bikes in the past that I have really loved. I did love (and often enuf' hate) my Commando's and before them the 600 and 650. Prewar tech but the isolastics when properly shimmed provided a wonderfully cushioned motor that loved to rev (and wore accordingly). I still have a soft spot for the cb400 fours of the 70's. None of these bikes are particularly exotic or even modern but I just like them in the same way I like the CBX. For a subtle combination of subjective reasons.
Unlike many of my contemporaries however, I do not like spending a lot of money on motorcycles and in fact I find the prices of many bikes today to be verging on obscene, even allowing for 50 or 60 years of inflation. I expect the Chinese manufacturers like CF Moto to shake up this market. We are already seeing their 450 twins rising in popularity against Japanese budget race/road bikes like the little Ninjas and R3's.
- Amazing Poster
Re: CBX Racing
Not a CBX job but something to settle my nerves b4 next w/e's races. The VFR800 that I effectively swapped my NC30 for has a very irritating gearchange in that it does not possess a linkage and accordingly, cannot be reconfigured to GP shift pattern. Of course, I use GP shift on my race bikes so the roadbike pattern is a problem that is normally a 5 minute job to fix. But not without a linkage. Why Honda, why not put a linkage on your most popular sport/tourer? This has prevented me from riding the thing because the last thing I need is to get muddled up when changing gears automatically or in a hurry.
So having managed to get both the CBX and the 701 ready for racing I had time to tackle the VFR800. I am quite proud of the linkage that I fashioned from old bits and pieces I had lying around and best of all it works perfectly to give me a good GP shift pattern. Here is a pic. The space was typically restricted, Honda's castings difficult to replicate by hand in half inch alloy plate with and angle grinder and dremmel and the angles tricky. Finally, some jury-rigged engineering on the shaft to both locate the peg firmly while allowing the mechanism to rotate smoothly.
So now I can ride it without confusing myself over shift patterns (and I saved myself around $1K for the only aftermarket linkage available for the VFR800.
- Amazing Poster
Re: CBX Racing
I promised Fran that I would retire from racing after the Seniors Races that I contested over the last 3 days. I am happy to report that I finished on a high note with 3rd overall on points in the heavy-weight P5 Unlimited class on the Lump. The CBX ran faultlessly all w/e and never put a wheel wrong even tho' my confidence was down and I was 3-4 seconds off my best times. This always happens after a crash and I did get quicker with each race.
Here is the pic my club used for their facebook page. I had the big GS to contend with again. Even tho' I qualified well with P5 in the middle of the second row I held back on the starts to avoid the melee in the first few turns that brought me unstuck in the Classic a few months ago. I then had to work my way thru' the field once everybody was a bit spaced out. For those who do not follow racing the most dangerous part of any race is the start when half the grid are technically out of control with their front wheels in the air. The next few corners are then hotly and aggressively contested as 20 or 30 riders bang elbows fighting for a limited amount of space. If you have only watched bike racing on TV you will not appreciate just how physical these clashes can be. I did not fancy another trip to hospital and accordingly discretion was definitely the better part of valour and this time I managed to keep my head.
my conservative tactic was not likely to produce any silverware because in sprint racing a good start is critical. And so it transpired that by the time I had worked my way thru' the field the leaders had gone. Generally, the pecking order is pretty clear from practice times and in each race the fastest riders were fairly consistent. My task grew more difficult as I closed on the leading group. Finally, the big GS was difficult to get past and in each of the races we had close and exciting last lap dices in which I happily prevailed. The final results were the same in each race with the Lump coming in third. Can I again just say to the sceptics,
the CBX is more of a good platform for a race bike than they think?
- Amazing Poster
Re: CBX Racing
Here are a few of Fran's amateur shots from the w/e.
Re: CBX Racing
Thanks for all the content you have provided the forum Rick, you have a lot of fans here!
Jeff
- Amazing Poster
Re: CBX Racing
Thanks Jeff, compliment appreciated. I will continue doing track days and if the 2025 National Historic Championships are to be held at Phillip Island as currently mooted, I would like to put a team together around the Lump with a talented young rider on board. I can also think of plenty of things that I would like to change. Here are just a couple:-
Get rid of the heavy iron liners, take it out to the full 1300 capacity limit and Nikasil the bores;
Have the head properly flowed and lighten the cams and valve gear (titanium valves and collets, shim under bucket, etc);
Replace the heavy ZZR rear wheel with a much lighter mag;
Install a lightweight racing alternator;
Install a dry slipper clutch on the other side.
In the meantime, I will continue trying to arrest or at least slow the decline of my riding skills with the 701 pictured below.
Back to the Crighton rotary for a moment: over the w/e I was talking to Nick, the owner and he had some interesting observations. In his view the bike is almost unrideable because of the light switch power delivery. I suggested he just needed to get used to it but he was doubtful. Coming from a 2 stroke background he is used to peaky power bands. He was also doubtful about the formation of an owners' forum to share running info because he thinks very few, if any will ever be ridden, much less raced. The limited production run would tend to lend creedence to his observations.
- Amazing Poster
Re: CBX Racing
Just as a postscript; I would not expect too many CBX enthusiasts to be too interested in a modern single but here are a few stats:
capacity 692.7 ccs; track wet weight -130kgs; track power - 85 rwhp; torque - 65fllbs; 2 way quick shifter & slipper clutch with traction control; Brembo M50 monoblocs with Z04 pads. Nb: power to weight ratio is Superbike equivalent but with superior braking, more nimble handling and fractional running costs
Re: CBX Racing
It’s more than a compliment Rick, you are living the ICOA’s moto “The International CBX Owners Association
Dedicated to the enjoyment and preservation of the 6-Cylinder Honda CBX-1000 Motorcycle”.
You are out there for people to see and enjoy your hard work, not just restoring something old to sit somewhere in a corner. I have saved your pass on the GS and it has become my favorite CBX picture and it will get posted by me whenever someone has a doubt that a CBX and a good rider can’t compete!
- Syscrush
Re: CBX Racing
I'll echo what Jeff has said. You've shared so much information AND enthusiasm, and I love your dedication to the CBX as a platform.
Looking at your proposed "no limit" modifications got me thinking more about what could be done with that engine. What are your thoughts about filling the wonky intake ports and replacing them with a straight, more modern design?
As I recall, part of what you like about the CBX is the broad spread of midrange power, and to my understanding, those different length/angle intake ports should actually help with that, so maybe it's not a good idea, but I'm curious about your thoughts.
- Amazing Poster
Re: CBX Racing
Phil I seem to recall reading somewhere that somebody had already experimented with that. Variable intake lengths are more or less old hat now altho' I remember when BMW first introduced them on their 1000RR and thoroughly creamed the opposition with at the time record superbike power outputs.
I think the problem is more to do with the impeded gas flow due to the angles rather than intake length per se. If you straighten out the ports you then have a packaging problem with the carbs interfering with the rider's knees. Another way to tackle it could be using 3 twin choke carbs and that would be allowable under the historic rules because I know Kawasaki experimented with Webers on their 4's back in the day and they employed 3 carbs on their Z1300 six too. Has anybody tried Webers on a CBX?
If you could get rid of or minimise the batteries with a race alternator and free up space behind the carbs, then fitting an airbox should help, especially if you can generate a ram air effect with some ducting but to do it properly you would need access to a wind tunnel to study the aerodynamics and to keep it looking 'period'. Fitting an airbox something like the original but with flutes to catch the air might work but it would be tricky tuning the smoothbore carbs for both high and low pressure.
Sorting out the CBX gas flow is a job for a skilled engineer with a good understanding of thermo-dynamics and the right gear. These talents are out there but finding somebody with the skills and capacity willing to apply them to a 50-year-old design is a big ask. Personally speaking, tackling it trial and error is not a place I want to return to now that I have found a stable and reliable package that is eminently rideable. Incremental improvements to the existing design are still achievable without getting into more experimental or exotic areas.
I will trade power for fuss free raceability any day but perhaps, I'm just showing my age again.
- Amazing Poster
Re: CBX Racing
Just one other point; the improvements I outlined above should shed over 30 kgs of weight and that would be far more beneficial in a race bike than an extra 30 hp, altho' I think both are readily achievable with an appropriate budget.
Re: CBX Racing
It’s been done before, the cost and hours involved with the welding, machining and fabrication yielded a 10% increase in HP, in the end it was determined not to be cost effective for the effort spent.
- Syscrush
Re: CBX Racing
Thanks, Jeff! Do you know where that photo came from, or who did this work?
I thought I had seen something like that before, though I know I've definitely seen the same treatment on an SOHC4 Honda (which is kind of what gave me the idea), so I wasn't sure if I had imagined it.
I would dearly love to see that before & after dyno traces for that head.
- Amazing Poster
Re: CBX Racing
There I was thinking BMW were the first to introduce variable length inlets when I should have known because all along I had a VTEC VFR800 sitting in my workshop and it has variable length inlet trumpets operated by solenoids nestling in the 'V'. Honda again leading innovation in the road bike pack!
Interesting that altho' MotoGP has been taken over by electronics boffins and there are more laptops in action crunching data from transponders than there are riders riders riding the bikes, leaving Honda languishing at the bottom of the pecking order; altho' Honda has fallen from it's previous dominance to a Volkswagen subsidiary, The top 10 bikes at the 2024 IOM TT are all Fireblades, a couple of BMW's and a single Kawasaki. Not a Volkswagen in sight!
Here are a few more high resolution professional pics from the Lump's recent outing from Pit Lane Studio.
- Amazing Poster
Re: CBX Racing
I gave the Lump it's regular post outing oil change, drained about a cup of oil from the breather condenser bottle and charged the batteries, but what now? Is there anybody out there who might be interested in continuing this journey with my faithful Rocinante?
