Hello and help
Edster
Hello and help
Post by Edster »
The automatic fuel valve on my 81 pro link has a torn diaphragm, I’ve discovered this part is made from unobtainium, any suggestions on how to repair or find a new valve?
Edster
Re: Hello and help
Edster wrote: Sun Sep 19, 2021 10:04 am The automatic fuel valve on my 81 pro link has a torn diaphragm, I’ve discovered this part is made from unobtainium, any suggestions on how to repair or find a new valve?
Edster
Just removed the whole valve system, do a search there is a lot of information on it here, maybe even an aftermarket source in the information, don’t know but it’s worth the search here.
Re: Hello and help
Many of us just remove that valve and use the petcock as an ordinary system. However, if you do want to replace it Louis Mintrone can likely have one. usedcbxparts@hotmail.com I don't know of anyone making replacement diaphragms.
CBX1000FAN
Re: Hello and help
Post by CBX1000FAN »
I replaced mine with a normal gravity feed one. Just close the tap after each ride....
Re: Hello and help
CBX1000FAN wrote: Mon Sep 20, 2021 3:47 pm I replaced mine with a normal gravity feed one. Just close the tap after each ride....
That works best! (You won't forget to turn it on. Automatic reminder within first km. :P )
Edster
Re: Hello and help
Post by Edster »
Thanks everyone for your help, especially Larry for Louis’s contact email. I contacted Louis and he took care of me. I thought about bypassing the automatic fuel valve but wanted to keep the bike stock. Thanks again for the help!
Edster
cross
Re: Hello and help
Post by cross »
Edster
Is your valve with 3 or 4 screws?
Sasha
'82 Honda CBX
'99 Triumph TBS
'01 Honda Valkyrie
:auto-sportbike:
Edster
Re: Hello and help
Post by Edster »
3 screws, I sourced one from wwwcbxparts.com.
cross
Re: Hello and help
Post by cross »
Diaphragms are not available for those. If you had gotten 4 screw one like the one for '82, diaphragms are still available
Sasha
'82 Honda CBX
'99 Triumph TBS
'01 Honda Valkyrie
:auto-sportbike:
sed213rr@gmail.com
float needle stuck
Post by sed213rr@gmail.com »
How do I unstick a needle w/o removing carbs ?
sed213rr@gmail.com
float needle stuck
Re: float needle stuck
sed213rr@gmail.com wrote: Wed Oct 06, 2021 7:11 pm How do I unstick a needle w/o removing carbs ?
From Mike Nixon.
https://motorcycleproject.com/text/cbxcarbs_short.html
