I settled on using the the frame for the 'B' bike and therefore the engine case from the same bike. Cylinders and head will be from the 'A' bike. I'll compare all the internal case components and choose those that have the least wear.
I plastigauged all the bearing and rod journals on the crank. The acceptable wear limit is 0.08mm for all crank bearings and most of the crank to case bearing clearances are just under (~0.07mm). The rod bearings were slightly looser, some over the wear limit. I'll be investing in a full set of bearings
. The good news is the wear was even, no deep scoring on the crank journals, just some very light grooves that should polish out easily.
I don't' have the means to accurately check the run out, spec is just 0.002" (0.05mm). I can't see how it would be out of spec with the bearings wearing this evenly.
Took apart the oil pumps from both engines, cleaned in the parts washer and the ultra sonic cleaner. Both pumps show very little wear, all well within the specs in the service manual. I'll need a new pickup screen, the rubber is very brittle and will surely break if I try to stretch over the intake housing.
Is there much else to the pump to be concerned?
