Removing bar ends
DaveMadsen
Removing bar ends
Post by DaveMadsen »
Putting a 1979 together and I see one of the bar ends is missing. I thought I would remove the other but want understand how it is attached to the handlebar. I assume it is threaded, but for the life of me I can’t break free the remaining bar end (it is the left side so may be susceptible to water/rust. Can someone confirm if the bar ends are threaded (and if they have reverse threads - I don’t want to be cranking on it only to find out I am trying to turn it the wrong way)?
jnnngs
Re: Removing bar ends
Post by jnnngs »
Yes, threaded (not reverse threaded)
They do stick, but normally come off OK with a little brute force. You could try some heat - that will probably help.
Paul.
tevan
Post by tevan »
I bet it won’t come out easily because it has never been out. The other guy probably tried it and gave up. I have extra bars if you have a bad experience. Good luck.
Heat
DaveMadsen
Thanks, I solicited the help of a 2' breaker bar and the bar end came around to my way of thinking. Now, two questions: (1) where can I get another bar end to replace the one which was missing, and (2) any recommendations on non-OEM bar ends, preferably ones which would use the same threads.
Again, thanks for everyone's suggestions.
