This happens with my clutch as well on the first ride of the day. I just keep it on the center stand while it warms up and shift back and forth from neutral to first until it releases or I wait until it settles into a nice idle, shift into first and simultaneously increase throttle and apply the rear brake.
I asked my mechanic to have a look at it and He said the clutch was in good order.
Clutch not disengaging
- wyly
Re: Clutch not disengaging
Punctuation is your friend!
All you have to do is start the bike and let it warm up for a few seconds. Pull in the clutch lever and "blip" the throttle a couple of times. This will free up your clutch if everything else is working correctly. Done that with all 26 of the bikes I have owned and it worked on all of them.
Revisiting this again as I can't believe it would be doing the gearbox much good by having drag.
On centre stand with 1st engaged and clutch lever pulled to disengage I can only get the clutch to release with a fair amount of force on the rear wheel. Once free it still drags quite a bit. Tried the same when hot but still takes some effort to get the clutch to release. So it would appear that there is not enough rod travel to separate the plates to disengage fully. I have checked and rechecked my stock setup for excessive grooves on the basket etc and it is correct. I even tried dialling out all the cable slack but no change
Would a slightly longer rod cure this issue or is this just a wet clutch feature?
Maybe I'm being pedantic but it just doesn't seem right although it is an often reported issue.
