Drilled slides
Drilled slides
Does anyone know how much slides that were drilled for a dynojet stage 3 kit will affect a 79 with stock jets,needles and airbox with stock filter.
- ICOA Rally Director
Re: Drilled slides
Mike,
I seem to remember that someone drilled the slides with poor results. Something about the slides responding too quickly, allowing too rich mixture and ensuing stumbling. You might try doing a search while you wait for the carb guru's to show up.
Re: Drilled slides
It's not much - some with Dynojet kits were never even drilled. I've put '79 carbs back to stock with drilled slides and the bikes seemed to run fine. No guarantees though.
- FalldownPhil
Re: Drilled slides
+1 with Dave !!
I have had Mike Nixon bring back to stock multiple sets of '79 carbs that had stage 3 kits done to
them with very good results. Apparently the drilled slides do not make a big difference
as the bikes ran very well. Finding the stock slide needles however is getting more difficult.
Phil
Phil
- Mike Nixon
Re: Drilled slides
I believe enlarging the holes serves to eliminate or nearly eliminate the slight lag with which the slide responds to throttle movement, a designed-in characteristic of the CV carb and what makes it such a good street carburetor. The airspeed is always ideal and therefore fuel discharge instant regardless of throttle opening. The presumed goal of enlarging the hole is I am convinced to defeat this characteristic, to make the CV carb act more like a mechanical lift carb, i,e, one with a linear, lockstep throttle/slide relationship. This is something really undesireable for the street, useful only on the track, believe me. The catch is, mine and Dave's and others' experience would indicate the benefit of hole enlargement, i.e. the lag reduction effect, if that is in fact what the result of hole enlargement is, is either noticeable only at extreme rpm/load/throttle combinations possible only in racing conditions, and thus not perceptible on the street, or, enlarging the hole has absolutely no effect, which is equally as likely. Like Dave I have reversed countless Dynojet kits (what junk!) and after the first one have never given a thought to the holes.
I have on my site a graphics-intensive article that focuses on the function of the CV carb, it may help some understand this. Unfortunarely, someone hacked into my site a few weeks ago and totally destroyed it, requiring me to completely rebuild it, which I am doing.
It's really incredible how well the CBX's made-to-a-cost carburetors work. Once properly fettled, it's hard for me to imagine anyone would want to modify them.
Re: Drilled slides
So sorry about your hacked site, Mike! Hate to even imagine that or ask what/who is responsible. Hope all else is well!
- Mike Nixon
Re: Drilled slides
Thanks Dave.daves79x wrote:So sorry about your hacked site, Mike! Hate to even imagine that or ask what/who is responsible. Hope all else is well!
Re: Drilled slides
<<Unfortunarely, someone hacked into my site a few weeks ago >>
Who in the world would do such a thing? Not that I don't have a suspicion........![Think :think:](./images/smilies/eusa/think.gif)
