Upgraded alt. charging question
Fred Garvin
Post by Fred Garvin »
Greetings,
I am having charging issues with the upgraded alt. mod I did a while back. Just recently, I noticed that it will not provide adequate charging at idle ( 6-8v, ) yet at 2500 rpm and up, it charges at 12v. At normal cruise, I would see 12-13 v. I checked with a multi meter and found that I am off about one volt vs. the meter on the bike. Anyone else with this mod run in to this? Can this unit be repaired or am I now looking to replace this unit?
Thanks.
herdygerdy
Re: Upgraded alt. charging question
Post by herdygerdy »
Hi Fred,
Welcome to the site. What 'alternator mod' did you do? More info' and we'll be happy to help you lift the bonnet.
Cheers..Tony
Fred Garvin
It is the the kawi zx7r alt. mod. I installed it a few years back and purchased it from a gentleman that that had it listed on this forum. It is the same one now listed on Tims CBX.
Mouse
Post by Mouse »
:text-welcomewave: To the site Fred.
ICOA Rally Director
ICOA Rally Director
Yes, welcome. Where in Colorado do you live? There are several members out there. I can think of three, in Aurora, Westminster, and Grand Junction.
Fred -- I assume your multi-meter check was across the battery terminals. That should read 14 to 14.3 at about 2500rpm. Another check is all connections between alt and battery. One ohm of resistance, either at one connection or total, can lead to loss of 1 volt easily. Things you have likely thought/done. But, always worth the mention.
Fred Garvin
Home is Montrose CO closest to Grand Junction. I did the meter check and found about 12-13v at an estimated 2500 rpm because my tach cable broke the same time my alt went south. I believe these are Nippon Denso products that might be able to be fixed. I droped it off at a local alt. shop ( familiar with motorcycles him self)along with the battery for a load check. Waiting to here back. Would an off the shelf zx7r alt bolt right on?
Thanks.
Is there a list of owners available?
ICOA Rally Director
ICOA Rally Director
We used to have a member who was a pilot, flew out of the Montrose airport on US 50 north of town.
You are blessed with some very good roads............ :mrgreen:
Fred have a read through this thread about upgraded alternators.
viewtopic.php?f=21&t=8141
J.R. is no longer offering his upgrade but there should be some info that you can use.
I would also contact Tims and see if they have any ideas.
Those ZX alternators have an internal regulator that seems not to be replaceable - not sure about that though. Yes, another should bolt right on to your adaptor. 13 volts max is too low and will run your battery dead. I assume the unit charged better in the past?
Fred Garvin
Got word from my alt. guy that the diodes are ok, brushes are like new and the batt. is charged and was load tested to be ok. After I recheck the connections and reinstall to get the bike started for winterization, any suggestions on what my next purchase step might be? Tims has one but pretty expensive espically since I already have the adapters. Possible suggestions for an out fit to re build with a new reg. or rectifier?
FalldownPhil
Post by FalldownPhil »
You should be able to pick up another alternator just like what you have either on eBay or from a M/C wrecking yard for about $50-$75.00
Just utilize the adapter etc.
Phil
Not quite sure what you are asking, Fred.
Everything on the alternator checks out and now you are aiming at a reg/rec?
If you are still looking for an alternator for your adapter some models can be found here.
viewtopic.php?f=21&t=7269&p=55479&hilit=denso#p55479
Like Phil says, usually $75 range on Ebay.
Fred Garvin
I should have been more descriptive: he was unable to do a spin up on the alt. to see if it was the reg/rec. Only did a static check (brushes, diodes). Not sure if there is any one out there where it could be sent for a full check. Ebay sounds like the best option.
Thanks so much for that link steve.
Fred Garvin
Any one know where I might find a voltage reg./part number for this unit? I would like to try this before I look for another alternator. Have not heard back from CBX-tras or Ricks electric yet.
