You can just use your garden-variety propane torch to heat the pilot screw tower and the screws will turn out. If you twist out the rather fragile screwdriver slot, don't panic, just mill an new one with a Dremmel and a small ball bit. Randakk's kits are the best. I assume you know you will need to separate the carbs. You also may need Randakk's rubber throttle joint covers and air vent Ts. Lots and lots of little tricks to get these carbs right and don't be frustrated if you have to try 2 or 3 times. We've walked lots of guys through this, so don't be shy about asking any little thing.
New from Lubbock, TX 2 projects
Re: New from Lubbock, TX 2 projects
No after photo Steve, I went comatose after the last bite.steve murdoch icoa #5322 wrote:Yeah, you go look for the pics of the carb while your faithful companion "guards" your dinner.
I want to see the after photo.
