race tech or progressive springs
wyly
Post by wyly »
Z
Re: race tech or progressive springs
Opinions on this will vary, but in my experience most wobbles start at the rear of the bike. I did the Race Tech and fork brace path for my fork and like it, but from a troubleshooting sense, before you start throwing parts at a handling problem, try to diagnose it first. Look at the swingarm pivot for starters, wheel bearings and tires, then the steering head.
All that said, I'm a big fan of the RaceTech setup, really improves these primitive damper rod forks.
wyly
Post by wyly »
Z
If you are replacing the shocks, swingarm bearings and tires i wouldn't spend any more money on it until you can take it for a ride.
Fork internals and a brace MIGHT not be required.
wyly
Post by wyly »
Z
wyly wrote:yeah good advice I was thinking along those same lines. Of coarse I don't want to find out if its not enough by experiencing another wobble at speed again, the next could be fatal. So not doing more is hard to resist, to have the bars nearly ripped from your hands at highway speeds isn't an enjoyable experience.
My technician who has been building drag and racing bikes for 35 years claims it's a front end problem due to spindle forks. Then there are posts Ive read in this forum that claims all handling problems with the z start at the swing arm bushings and shocks. Lots of experts all with valid opinions to be respected.
It's all about confidence, frankly. I'm with Steve, you've made really sensible mods so far and I think it's quite possible your bike is going to be excellent and your appetite for exploring its limits might be a bit diminished. So hang out a bit, you're not going to spend any more money to wait and see :-).
wyly
Post by wyly »
Z
ICOA Rally Director
ICOA Rally Director
You can nearly eliminate the wobble, or oscillation, of the front end by sliding your butt as far forward on the seat as practical, and leaning forward as well. Lower handlebars help here.
My '79 was terrible, and still is, if I don't make an effort to put more weight on the front tire.
Most of the wobbles in CBXes are caused by improper adjusted or loose steering neck bearings. 8)
Check what Mike Nixon has to say about this:
http://www.motorcycleproject.com/motorc ... cking.html
Wyly,
If it's a handlebar nibble type of 'wobble', most likely head bearings. Fork changes won't do much, if anything, for this. If it's an overall bike shake, it's what Rick mentioned. Especially, if it's at a speed over 70mph. In that case, check the rear suspension overall. Tire pressures -- set to spec. Yes, pressure too low can cause some funny things. BUT, too high will cause loss of tire damping which, then, helps to induce rear end wobble/shake. And, again, as Rick mentioned, get the weight forward! Especially, once a wobble/weave begins. That's the significant reason that the book will tell you not to put more than 10 pounds in the bags on the prolinks. (It may not be mentioned in the book for the early models because they don't have bags. Still applies!) If you are traveling with a duffel bag, etc. laid over the back just remember that this may contribute measurably to a severe head-shake; especially to any weight that gets behind the rear axle.
Have a safe ride.
wyly
Post by wyly »
Z
wyly, if you haven't already purchased the Metzlers i would check out PetesSuperbike in Montreal.
$500.00 seems like a lot.
Pete's has great prices with fast shipping.
http://www.petes-superbike.com/metzeler ... 1_167.html
