Hi,
I'm still working on restoring a decent 79-80 Frankenbike. I dissassembled the fork over the week-end and I noticed one tube was showing more resistance than the other. I see 2 clear spots on the inside of the fork slider. I can't really tell if this is normal casting shrinkage or if something REALLy bad happened in the past. I did have to bully the fork to pull out the seal, I think it was the original piece and that fork never been serviced. The stinking green goo I cleaned up tells me it never was (grossiest non-body fluid I've ever seen! . I hope I didn't inflic these damages myself, although I bullied both tubes equally, only one showed up damaged.
My question is : is this damage too important to have a safe/reliable fork assembly? I don't plan to have it filled and machined since I have access to a second bike for parts ('79 though). I assume I can use the slider from the '79 or the whole fork assembly. I prefer the cross-drilled discs but I also assume they are interchangeable.
Comments?
Side note : the internal components of the damaged fork are in decent shape. The bottom piece (looking like an empty gun shell) do look a bit damaged compared to the other side of the fork. I haven't found any debris in the dropped fluid, weird... that bike wasn't functioning when I got it so I can't comment on the ride or if the fork worked correctly.
and bonus!
'80 Damaged fork sliders...
- not_bob_3
Francis from up North
'80 CBX / '08 KLR 650 / '70 Motobécane Pantin / '11 Accord coupe V6
"CAD guys do it with models"
- not_bob_3
Re: '80 Damaged fork sliders...
bump!
anyone?
anyone?
I'd go ahead and use it, I guess. Make sure all the buggered area is smoothed off on the edges.
The sliders of the 79 differ from the 80.not_bob_3 wrote: I assume I can use the slider from the '79 or the whole fork assembly. I prefer the cross-drilled discs but I also assume they are interchangeable.
- not_bob_3
Thanks for the heads-up!EMS wrote:The sliders of the 79 differ from the 80.not_bob_3 wrote: I assume I can use the slider from the '79 or the whole fork assembly. I prefer the cross-drilled discs but I also assume they are interchangeable.
