How to: Restore your carburetor insulators and rubber bits
cbx6ss
Re: How to: Restore your carburetor insulators and rubber bi
Post by cbx6ss »
Copy that Dave. Thank you. I tried Acetone; just cleans REAL NICE. Next up was PVC primer and "glue". No softening observed. Last was classic Super Glue. Some tack, but no significant bond after 15 minutes (like when I get it between two fingers)... Might go towards Dave's recommendation. Going to look into roofing adhesive. Stand by...
/r
B
cbx6ss
Post by cbx6ss »
Still searching for an adhesive for the plenum box. Learning more about plastics than I ever thought I wanted to. Some really good info here if you have time for a read: http://www.henkelna.com/us/content_data ... 756739.pdf
Seems the assembly may be made from a "hard to bond substrate" type of plastic referred to as "TPV" or thermoplastic vulcanizate. Now to find an adhesive.
/r
Brad
cbx6ss
Post by cbx6ss »
Here's one candidate. About $80 to the door with 35ml glue, mixing nozzle, and "special" dispenser.... OUCH!!!
http://www.tamarrontechnology.biz/store/adhesives.html
/r
Brad
cbx6ss
Post by cbx6ss »
So as another alternative, I looked on ebay for a used box. I wonder why everyone tears out the carb boots from the boxes for sale?
/r
B
Brad:
I just realized that the late model air chambers aren't meant to come apart. The early ones that I was referring to have screws all around the front so that you can take it apart. Yes, you'd have to find a decent adhesive to put back together. Try E6000. Available at about any craft store/hobby shop. I use it for lots of things like this and it works great. Cheap, Too.
cbx6ss
Post by cbx6ss »
Thank you for the info Dave.
Brad,
Yes, E6000 is good stuff. Another good one I've found is J-B Weld Plastic Bonder. Comes in a Hypodermic type thing that you just squirt equal amounts as needed and mix. A nice reseal cap that lets it be stored easily. Can be used for almost any material. As always, with any adhesive, be certain to rough the surfaces and clean them before gluing. (Home Depot)
kbart1
Location: burnaby Burnaby, British Columbiabritish columbia
Post by kbart1 »
hey guys
so I did the wintergreen and xylene on my boots and it worked awesome. question now is, after I pull the boots from the solution do I need to stop the process somehow or neutralize the solution somehow? I am ready to take them out of the xylene/wintergreen bath but what now????
thx
kent
Nope, just rinse them off and enjoy the minty-fresh smell of your shop for a while :-).
I bought a nice clean paint can at Home Depot and saved the brew.
Glad it worked well for you Kent!
kbart1
Post by kbart1 »
thanks nils
how's the weather down there right now? heard your getting some of that Cabo storm? heading to phoenix on Tuesday for a few days, hope it dries up....... boots came out great, always amazed at all the little tricks we can learn from you guys here.
thx
kent
Thanks Kent,
The storm has been a dud here so far, we will see what tomorrow brings. I did read that Cabo got hammered, did you check in on where you're headed?
Dying to go to Baja, will do that soon.
