29mm Smoothbores
29mm Smoothbores
Just something different to look at.
I just finished a full refurb of my Mikunis. Ulta-sonic, carb dip, guitar strings...the works.
Gaskets, o-rings, and info from Z1 Enterprises.
Hopefully be going on the '79.
Re: 29mm Smoothbores
JP has been running them for years and swears by them, maybe he'll chime in.
kbart1
Location: burnaby Burnaby, British Columbiabritish columbia
Post by kbart1 »
those look awesome Steve! i can only wish! great job!
steve murdoch icoa #5322 wrote:Just something different to look at.
Very cool Steve!
But I'm puzzled by the straightness of the bank of carbs. Wouldn't that vary the length of the intake tract in a bad way?
Very cool Steve!
You compensate with different length carb boots, similar to the intake on the CBX, it's not perfect but the tracts of the CBX head are so unequal I don't think it matters much.
Jeff Bennetts wrote:[ the tracts of the CBX head are so unequal .
That's why the Honda engineers gave the CBX an airbox and designed it the way it was. One of the reasons pods don't work that well on a CBX.
I think Larry Benjamin had a set of smoothbores ( I maybe wrong) on his CBX and he loved them too. Rick's Tricks had a set of special carb boots available when he sold his Flatslides for CBXes
I do have the Ricks Tricks manifolds that are in surprisingly good shape.
A couple searches has provided info from Larry Benjamin, J.P. and John D. from Kansas.
Larry even used different jetting on carbs 1 and 6. PipeMasters and K&N pods will be going on mine.
The big reason pods don't work well on stock CBX carbs is they need vacuum to move the heavy slides they use, that's one reason why they are called constant velocity CV carbs and the fact that they automatically adjust to different altitudes, the lack of vacuum affects the throttle response because the slides have to catch up the the fuel flow. The 29 smooth bores aren't CV and don't suffer this problem when using pods, the Siamese pods now sold for stock CV carbs are better than the single pods though.
Rick is still around and I do have his contact info if anyone needs it.
Last edited by Jeff Bennetts on Wed Mar 14, 2012 9:28 am, edited 3 times in total.
Exactly, I bet 90 percent of CBX owners have never opened up the intake portion of the CBX's airbox to see the different lengths of the intake runners inside.
