Valve seal removal
kbart1
Location: burnaby Burnaby, British Columbiabritish columbia
Valve seal removal
Post by kbart1 »
i have searched all the posts i can think of trying to find out how to REMOVE the valve seals from the head? i found a great tip for REPLACING the seals but nothing on getting them off the head. any tips would be much appreciated.
thanks
kent
Re: Valve seal removal
Hook 'em with a seal pick - you can't re-use them anyway.
kbart1
Post by kbart1 »
thanks dave, when you mention "seal pick" do you mean such as a dental pick? tried dental pick and bent it???
SteveG
Post by SteveG »
Try a paint can opener. Works great.
Be careful when asking for them at Lowes, Home Depot..... You may have to duck when they throw them at you!
Steve
4878
Kool_Biker
Post by Kool_Biker »
Here's using a 'proper' seal remover tool. Go for the smallest size you can find.
Do note the blue 'nylon cup' insert in the valve well. This is extremely important to ensure you do not scratch anything as you insert the tool or as you pull the seal!
Aris
Aris Hadjiaslanis
ICOA # 6309
Berkshire, Windsor
Here are pictures from another thread. See the 35mm plastic film cartridge! If you cut one of them lengthwise and cut a narrow slice off, they will make excellent protectors for the hole the valve sits in. You don't want to mar the walls with the tool as the bucket needs to slide in there.
The valve seal remover is a Schley product. It can be bought on line or at sears. details at the end of this thread:
viewtopic.php?f=20&t=7018&p=54162&hilit ... eal#p54162
4604
4606
