Is it possible to replace an 85mph speedometer (on an '82) with an earlier 150mph version? Does a 150 speedo require some sort of drive speed corrector in order to show the proper speed or are the speedo internals preadjusted from the factory?
Thanks,
Newbie Dave
85mph Speedo Replacement
Dave Bell
1982 CBX
2000 BMW K1200LT
1972 Detomaso Pantera GTS
2005 Acura NSX
2008 Roush F-150
1982 CBX
2000 BMW K1200LT
2005 Acura NSX
2008 Roush F-150
Re: 85mph Speedo Replacement
The 150 will bolt right on, but you lose your rear shock low pressure warning light - if you knew you had one. Now the problem is finding a good 150 that matches your degree of fade.
And, at a price less than a mortgage!
Is it possible to turn an 85mph speedo into a 150mph one. I've got a good working 85mph speedo which i would like to refurb and turn into a 150mph one using replacement decals, but the needle will obviously read incorrectly too high a speed. Is it possible to get anything to change the gear ratio inside the clocks or is it simply a case of getting my hands on a scrap/damaged 150mph clock and using that as a donor. I did read that a guy at randakks, pete, did a conversion on the 85mph to turn them into one to read 150mph. Don't know if this is still the case. I'd like to do it myself is possible
Thanks,
Shaun
Thanks,
Shaun
