Still with the cylinder head today, BUT opening a new chapter at last: VALVES.
This chapter begins with a good clean, to remove what ever debris was created during the cams operations and any remaining glass (paranoid
The head was dried with lots of compressed air and next the cylinder head domes and valve seats were cleaned from carbon buildup, ever so
lightly, using the softest 3M abrasive on the Dremel.
Then all 24 valves were cleaned using my Bosh drill at high speed and a rotary brass brush. They were subsequently carefully inspected for any sort of visible damage.
Happy to report, other than the small cracks in exhaust valves in cylinder no 1 (reported extensively earlier on), there was none
I then went on to lap one (inlet) valve to create a gas-tight seal between the valve and the head, using fine grinding paste and a small hand lapping stick.
All very easy, satisfying and looks great.
BUT, I have stopped here to ensure I do not get overenthusiastic with anything.
In fact, I have a question for you chaps; below is a pic of an inlet valve BEFORE cleaning.
There's clearly a little bit of carbon buildup (red surround),
exactly where the valve/seat seal should be.
How can this be explained, considering that the seats and valves were professionally cut (and I guess lapped) only 110 miles ago? I would like to understand this before I get on with lapping all remaining valves. Any suggestions extremely welcome. I am also happy to be told I am splitting hair
Cheers, Aris
