Cam installation
CopperCollar
Cam installation
Post by CopperCollar »
Well guys, I have a 79 that I am pulling the head off to inspect for bent valves and then reassemble. I see that my service manual is dated Aug 78...so section 6-22 last paragraph.
" Turn the crankshaft clockwise 360 until the "T" mark is aligned with the crankcase mating surface. Make sure the cam lobes for the #6 cylinder are toward the outside"
Is this correct? I would really hate to get the cams in wrong.
Mike
Re: Cam installation
That should be the correct wording in this paragraph.
Check the bottom of the page. It should say Date of issue: August, 1978. The original version, as shown on bottom of page 6-23 says Date of Issue: March 1978.
CopperCollar
Mucho Gracias.
Looks like the whole cam install is on the back burner, #1 rod is 10-7..bent like a dogs hind leg.
Mike
