CBX Frame material
CBX Frame material
Can anyone tell me specifically what the '79 frame is made of? I remember reading somewhere it was more than simply a steel frame.
CBX Frame
The frame is/was a diamond-type, tubular chrome-molybdenium steel frame with the engine as a structural member. Chrome-moly steel frames are nothing special, though. It is also sometimes referred to as "mild steel"
Chrome Moly Frame Tubing
I believe that EMS is correct on the CBX frame tubing material - I recall reading that Honda used chrome moly (4130 CroMo). The primary advantage that CroMo tubing offers over mild steel is strength. In example - a motorcycle frame made of mild steel would weigh ~40% more than one of equal strength made with CroMo (which would have a thinner tubing wall thickness).
The one comparative disadvantage of CroMo tubing is the welding requirement. Inert gas welding (TIG or MIG) is generally needed for CroMo frames. The welded frames (while still in the assembly fixture or "jig") were sometimes moved into an oven to "normalize" the material and to prevent brittleness in or adjacent to the welds. Without this process - the grain formations from welding could allow the frame to break.
I have seen mechanics use a gas tourch to accomplish this process after repairing a CroMo frame. But if extensive repair is required in an area such as a steering head - a fixture of some sort might be required to retain dimensional integrity.
Not a metallurgist or welder myself - these are just my observations from years past watching tuners repair tweaked CroMo motocross and dirt track frames - some of them mine :)
All the best,
John
San Jose, California
All the best,
John
Polishing the frame
Polishing alone should be no problem. Untreated - the polished frame will rust though - you may consider a clear coat of some type to prevent this (a bit more expensive - nickle plating looks sharp on some of the dirt track frames I have seen).
If the frame does need to be repaired/ welded - I would recommend taking it to someone experienced with chrome moly motorcycle frames.
Cheers,
John
Cheers,
John
Frame Polish
Yes, it can be polished. Although you may not get the chrome-like luster you would achieve with stainless steel. And then there is, like John says, the corrosion problem. Also, polishing a small diameter tube frame is quite an effort. Have you considered powder coating it ? Maybe in a different color than black?
coatings
How about HPC, they have the polished Alum finish and it is chemical resistent and can bare temps to 600 deg.Land_Shark wrote:Actually powder-coating was my first choice - until I saw one of the moto-martins with the chrome frame. I'm considering all three and will probably clear-coat over whatever I decide to do.
Thanks for the input
I'm working with a rep from HPC as speak to try and get a discount for all ICOA members,but it may take another month or so to finalize and I'm not making any promises just yet.
http://www.hpcoatings.com/
Jeff Bennetts ICOA #1111
