die hard agm battery
Has anyone tried the die hard agm battery? its time for a replacement.
Tom
Tom
- Don
- Amazing Poster
Hopefully they perform better than their namesakes - I used half a dozen 'Die Hards' back in the '70's . . . . never got more than 18 months out of any of them - Even replacing them under their pro-rated warranty, they were no bargain
I've had pretty good luck with WestCo (and the other various brands made by Johnson Controls) AGMS
- ICOA Travel Director
Haven't. I'm trying a Scorpion YTX24HL-BS 12 Volt AGM Maintenance Free 21AH with 350 CCAs in the 82 as the 6 yr old Westco in it went to my 79, now in its 7th yr of service! It was only $77 on sale at BatteryStuff.com. I only replaced the Westco because I tour on the 82 more than the 79 and wanted the assurance of a new battery for long rides. But, apparently as long as I maintain them with a Deltran Battery Tender Jr. they seem to run and run and run...
Ride em if ya got em....
I have had great performance from this battery.
http://www.batterymart.com/p-Big-Crank- ... ttery.html
- Don
- Amazing Poster
Pretty sure the 'Big Crank' is one of those made by Johnson Controls and at $73 it is probably a bargain - BTW . . . . a quick search shows that they also make the Die Hards too, so go with whichever one is cheaper . . . . likely not a dime's worth of difference in the internal construction of either
OK, prowling at Sears' site, this appears to be their top-of-the-line AGM equivalent:Don wrote:Pretty sure the 'Big Crank' is one of those made by Johnson Controls and at $73 it is probably a bargain - BTW . . . . a quick search shows that they also make the Die Hards too, so go with whichever one is cheaper . . . . likely not a dime's worth of difference in the internal construction of either
DieHard Gold PowerSport Battery 18L-BS
http://www.sears.com/shc/s/p_10153_1260 ... eviewsWrap
They want $94 for it in lovely tax-free NH (where I am headed today), with exchange, which saves me finding a way to recycle the old one. The Big Crank at the Battery Mart site nets out to $85 with ground shipping for me, so I'll likely go with this DieHard and hope that Sears' warranty adds some value if needed.
- alimey4u2
- ICOA Web Video Director
I did not, but looking at both pages, how could you tell? I see the Big Crank rated at 270 CCA, but I can't find any specification on the DieHard...TerryL wrote:You realize the Die Hard has much fewer CCAs right?
Thanks Terry,
- Don
- Amazing Poster
When comparing cranking amps, you need to pay particular attention to how they are rated/computed . . . . the adgvertising can LIETerryL wrote:You realize the Big Crank has much fewer CCAs right, 270 compared to the Scorpion's 350?
A true 250 cold CCA's (calculated as the amps the battery can sustain for 30 seconds at zero degrees) could be rated by another manufacturer as 350 CCA's . . . . and if it was done at 40 degrees (which is common) instead of zero, both batteries would actually be the same - 350 at 40 is the same thing as 250 at zero
It's almost as misleading as trying to figure which stereo has the most watts
