charging system solved
DevonCbx
Post by DevonCbx »
Thanks for the information everybody. I solved the charging system. Fortunetley I have a parts CBX in which I used the parts of the 80 CBX to put on my 79 CBX. Coupler plate A was somewhat chipped up. I took the whole charging system of the 80 and put it on the 79. I thought I would try this before checking the brushes etc. Well the bike charges about 13.5 volts in a rapid manner. The old system, when it worked, took awhile to come up to 13.5 volts. Also, can someone explain what is happening with these coupling plates. How does this unit create a charge? Tere is also another possible problem. I noticed oil in the cover. Is there an o- ring or something to replace?
Thanks :lol:
Terry
Post by Terry »
Those 'coupling' plates are the alternator's clutch plates. Although they aren't oil bathed, they are supposed to have some oil on them. No O ring to replace.
Great to hear, Duane.
Now you can give the entire '79 set-up a checkup. Nice to have a "parts bike" handy, although i prefer to call mine a "project bike".
Had the connectors started to cook?
Don #6141
Re: charging system solved
Post by Don #6141 »
DevonCbx wrote:I thought I would try this before checking the brushes etc. Well the bike charges about 13.5 volts in a rapid manner. The old system, when it worked, took awhile to come up to 13.5 volts. Also, can someone explain what is happening with these coupling plates
Did you move all the parts over from the '80? . . . . or do you have the '80 alternator with it's worn clutch plate on your '79 which still has it's worn clutch plate on the engine?
If the latter, you now have two mismatched worn plates which will take some time to wear into each other. During that time, they probably will 'grab' a little more fimly because they aren't yet worn to match each other
The clutch is there because the alternator diameter is large and it doesn't like being snatched around RPM wise as fast as the CBX engine can change RPM. The clutch plates are bathed in oil [maybe not the exact correct word] and are pressed together by a spring. When all is working well, if the alternator is outputting 20 or 30 amps at low RPM's, the plates are slipping some so the alternator isn't spinning as fast as the engine is idling, so it doesn't charge well at all below about 3,000 RPM . . . . which is why everyone tells you to make all electrical checks at 3,000 RPM and with a full battery. If that gives you 13.5 or better, your electrical system is working. Realize too that most alternators spin much faster than the engine does . . . . but not this one, so it's definitely 'challenged' below about 3K
There is a BIG 'O' ring where the alternator mates with the engine block because the clutch area has oil flying around . . . .
I seem to recall you had a burning smell? What did that turn out to be?
I don't know exactly what you've 'solved' except to change parts and now it works. There are several simple checks to do on the old alternator to determine what is wrong. They have been talked about here and elsewhere many times.
To your question - the clutch plates run in an oil bath that squirts out the end of the primary shaft and into the space between the plates and is slung out the 4 grooves in the drive plate. So oil is in that part of the alternator/cavity. The plates have to be properly mated and tensioned to work. The spring, shim washers and the plates themselves need to be in good shape.
If you find oil on the 'dry' side of the alternator - the seal in the middle is bad. There is an o-ring on the shaft where the driven plate is bolted also.
Now that you have a working unit, you can troubleshoot the old one and see what is wrong.
alimey4u2
ICOA Web Video Director
Post by alimey4u2 »
Good news Duane, thanks for the feedback... 8)
sixofsix
Post by sixofsix »
OK, I'll wade it.
I thought the pressurized oil through the center of the shaft increases volume with increased engine speed. The 4 "exiting" grooves in the clutch plate will only allow a certain volume of oil. High RPM, means the plates separate as the oil has to escape somewhere. Like a Kingsbury thrust bearing on a ship propellor shaft.
Or did I smoke too much "stuff" when I was younger?
Is this theory correct? I mean about the escaping oil separating the plates for all you smart alex's..
Tony
Don #6141
Post by Don #6141 »
I believe the total square area of the 4 exit grooves is a good but larger than the area of the hole in the primary shaft the oil comes from . . . . but you propose an excellent theory - If you're right, maybe the alternator never ever exceeds 6K or so no matter what . . . . but I doubt it. Controlling the overall speed by manipulating the slip would require an infinitely fine adjustment of the spring pressure on the plates and some way to change things automatically to account for clutch plate wear - I don't think Honda engineered things that way
In actual practice, the clutch seems much more prone to slipping at lower RPM' than higher . . . . at least by observing the voltmeter - Also, more load on the alternator means more slip and the faster the alternator spins the more likely that the voltage regulator will be lessening the load . . . . unless you have a heated suit or some extra banks of fog lights . . . .
sixofsix
Post by sixofsix »
U.B.I. from Wikipedia on fluid bearings. Sounds like it is a fluid bearing as it does not have the tilting plate design found in true Kingsbury thrust bearings. Dang! If it did, as stated below, the coupling would last at least 1300 years effectively throwing Jung & Loius outa business.
1300 years vs. 40,000 miles, Honda ain't dumb. Imagine the 1st CBX alternator coupling failure in year 3279, and Honda Parts make their first CBX replacement alternator clutch coupling sale! Then Jung & Louis' distant future relatives offer an alternative to the cheap 1300 year life one...with "CBX" on the billet Kingsbury housing.
See below for an interesting read (to some)
Fluid bearing
From Wikipedia, the free encyclopedia
Jump to: navigation, search
Fluid bearings are bearings which solely support the bearing's loads on a thin layer of liquid or gas.
They can be broadly classified as fluid dynamic bearings, hydrostatic or gas bearings. They are frequently used in high load, high speed or high precision applications where ordinary ball bearings have short life or high noise and vibration. They are also used increasingly to reduce cost. For example, hard disk drive motor fluid bearings are both quieter and cheaper than the ball bearings they replace.
Contents [hide]
1 Operation
2 Characteristics and principles of operation
3 Some fluid bearings
3.1 Foil bearings
3.2 Journal bearings
3.3 Air bearings
3.3.1 Examples
3.4 Kingsbury/Michell tilting-pad fluid bearings
4 External links
[edit] Operation
Fluid bearings use a thin layer of liquid or gas fluid between the bearing faces, typically sealed around or under the rotating shaft.
There are two principal ways of getting the fluid in to the bearing.
In gas bearings and hydrostatic bearings, the fluid is pumped in through an orifice or through a porous material.
In fluid-dynamic bearings, the bearing rotation sucks the fluid on to the inner surface of the bearing, forming a lubricating wedge under or around the shaft.
Hydrostatic bearings rely on an external pump. The power for that pump is arguably part of overall bearing friction. Better seals can reduce leak rates and pumping power, but may increase friction.
Hydrodynamic bearings rely on bearing motion to suck fluid into the bearing and may have high friction and short life at low speeds or during starts and stops. A external pump or secondary bearing may be used for startup and shutdown to prevent damage to the hydrodynamic bearing. A secondary bearing may have high friction and short operating life, but good overall service life if bearing starts and stops are infrequent.
[edit] Characteristics and principles of operation
Fluid bearings can be relatively cheap compared to other bearings with a similar load rating. The bearing can be as simple as two smooth surfaces with seals to keep in the working fluid. In contrast, a conventional rolling-element bearing may require many high-precision rollers with complicated shapes. Hydrostatic and gas bearings do have the complication and expense of external pumps.
Most fluid bearings require little or no maintenance, and have almost unlimited life. Conventional rolling-element bearings usually have shorter life and require regular maintenance. Pumped hydrostatic and aerostatic (gas) bearing designs retain low friction down to zero speed and need not suffer start/stop wear, provided the pump does not fail.
Fluid bearings generally have very low friction -- far better than mechanical bearings. One source of friction in a fluid bearing is the viscosity of the fluid. Hydrostatic gas bearings are among the lowest friction bearings. However, lower fluid viscosity also typically means fluid leaks faster from the bearing surfaces, thus requiring increased power for pumps or seals.
Since no rigid mechanical element supports load, it may seem fluid bearings can give only low precision. In practice, fluid bearings have clearances that change less under load (are "stiffer") than mechanical bearings. It might seem that bearing stiffness, as with maximum design load, would be a simple function of average fluid pressure and the bearing surface area. In practice, when bearing surfaces are pressed together, the fluid outflow is greatly constricted. This significantly increases the pressure of the fluid between the bearing faces. As fluid bearing faces are comparatively large areas, even small fluid pressure differences cause large restoring forces, maintaining the gap.
It is also very difficult to make a mechanical bearing which is atomically smooth and round; and mechanical bearings deform in high-speed operation due to centripetal force. In contrast, fluid bearings self-correct for minor imperfections.
Fluid bearings are typically quieter and smoother (more consistent friction) than rolling-element bearings. For example, hard disks manufactured with fluid bearings have noise ratings for bearings/motors on the order of 20-24 dB, which is a little more than the background noise of a quiet room. Drives based on rolling-element bearings are typically at least 4 dB noisier.
Tilting pad bearings are used as radial bearings for supporting and locating shafts in compressors.
[edit] Some fluid bearings
[edit] Foil bearings
Main article: Foil bearing
Foil bearings are a type of fluid dynamic air bearing that was introduced in high speed turbine applications in the 1960s by Garrett AiResearch. They use a gas as the working fluid, usually air and require no external pressurisation system.
[edit] Journal bearings
Pressure-oiled journal bearings appear to be plain bearings but are arguably fluid bearings. For example, journal bearings in gasoline (petrol) and diesel engines pump oil at low pressure in to a large-gap area of the bearing. As the bearing rotates, oil is carried in to the working part of the bearing, where it is compressed, with oil viscosity preventing the oil's escape. As a result, the bearing "hydroplanes" on a layer of oil, rather than on metal-on-metal contact as it may appear.
This is an example of a hydrodynamic bearing which does not use a secondary bearing for start/stop. In this application, a large part of the bearing wear occurs during startup and shutdown, though in engine use, substantial wear is also caused by hard combustion contaminants that bridge the oil film.
[edit] Air bearings
Unlike contact-roller bearings, air bearings utilize a thin film of pressurized air to provide an exceedingly low friction load-bearing interface between surfaces. The two surfaces don't touch. Being non-contact, air bearings avoid the traditional bearing-related problems of friction, wear, particulates, and lubricant handling, and offer distinct advantages in precision positioning and high-speed applications.[citation needed]
The fluid film of the bearing is air that flows through the bearing itself to the bearing surface. The design of the air bearing is such that, although the air constantly escapes from the bearing gap, the continual flow of pressurized air through the bearing is enough to support the working loads.
[edit] Examples
Air hockey is a game based on an aerostatic bearing which suspends the puck and player's paddles to provide low friction and thus fast motion. The bearing uses a flat plane with periodic orifices which deliver air just over ambient pressure. The puck and paddles rest on air.
Another example of a fluid bearing is ice skating. Ice skates form a hydrodynamic fluid bearing where the skate and ice are separated by a layer of water caused by entropy (formerly thought to be caused by pressure-induced melting; see ice skating for details.)
[edit] Kingsbury/Michell tilting-pad fluid bearings
Kingsbury/Michell dynamic tilting-pad fluid bearings were invented independently and almost simultaneously by both the American tribologist Albert Kingsbury, and a British-born Australian, Anthony George Maldon Michell.
The bearing has "shoes" or "pads" on pivots. When the bearing is in operation, the rotating part of the bearing carries fresh oil in to the pad area. Fluid pressure causes the pad to tilt slightly, building a wedge of pressurised fluid between the shoe and the other bearing surface. The pad tilt adaptively changes with bearing load and speed. Various design details ensure continued replenishment of the oil to avoid overheating and pad damage.
Kingsbury/Michell fluid bearings are used in a wider variety of heavy-duty rotating equipment, including in hydroelectric plants to support turbines and generators weighing hundreds of tons. They are also used in very heavy machinery, such as submarine propeller shafts.
The first tilting pad bearing in service was probably that built under A.G.M. Michell's guidance by George Weymoth (Pty) Ltd, for a centrifugal pump at Cohuna on the Murray River, Victoria, Australia, in 1907, just two years after Michell had published and patented his three-dimensional solution to Reynold's equation. By 1913, the great merits of the tilting-pad bearing had been recognised for marine applications. The first English ship to be fitted out with the bearing was the cross-channel steamboat the Paris, but many naval vessels were similarly equipped during the First World War. The practical results were spectacular - the troublesome thrust block became dramatically smaller and lighter, significantly more efficient, and remarkably free from maintenance troubles. It was estimated that the Royal Navy saved coal to a value of £500,000 in 1918 alone as a result of fitting Michell's tilting-pad bearings.
According to the ASME (see reference link), the first Kingsbury/Michell fluid bearing in the USA was installed in the Holtwood Hydroelectric Power Plant (on the Susquehanna River, near Lancaster, Pennsylvania, USA) in 1912. The 2.25-tonne bearing supports a water turbine and electric generator with a rotating mass of about 165 tonnes and water turbine pressure adding another 40 tonnes. The bearing has been in nearly continuous service since 1912, with no parts replaced. The ASME reported it was still in service as of 2000. As of 2002, the manufacturer estimated the bearings at Holtwood should have a maintenance-free life of about 1,300 years.
Currently, fluid film bearings are extensively modeled with finite element computer codes developed at the University of Virginia in the Rotating Machinery and Controls Industrial Research Program. This includes fixed pad radial bearings, tilting pad radial bearings, and thrust bearings. The analysis includes pressure effects, thermal effects, and deformation effects in the bearings. The codes are widely used by industrial firms.
An internal combustion engine that uses this type of fluid bearing to absorb the explosive forces generated is called a Bourke engine.
sixofsix wrote: for all you smart alex's..
Tony
Although I don't dare to get into the discussion about the fluid bearing and what the 4 grooves are actually doing or supposed to do...I can still be a smart aleck! (see, I was one already :roll: ):
1. Stefan Jung is no longer in the alternator business. He may make one for a friend, but he is not selling them "commercially" anymore.
2. Louis never made alternator conversions himself. He buys them from guy in Germany who copied Stefan Jung's design and sells them here with a mark-up.
alimey4u2
Post by alimey4u2 »
Can't be a fluid bearing...
A major component of a bearings duty is to reduce friction. If friction were reduced to the levels of fluid bearings the clutch plate would not transfer power & the rotor wouldn't rotate.. :idea:
Mr Honda calls it a clutch plate, tis a clutch plate... :lol:
Don #6141
Post by Don #6141 »
alimey4u2 wrote:Can't be a fluid bearing...
I agree - It's not as 'bearing' at all . . . . the shaft has conventional bearings and thus no need
It is a clutch . . . . running in oil which protects the alternator - And the alternator has bearings of it's own too ;)
