Baffels from kerker 6 into 2
cbxpearl
Post by cbxpearl »
Is there a trick or something to remove those end caps from a kerker 6 into 2. I removed the bolt but can't seem to pull them out. I need to repack the baffles.
thanks for any info...
bobber
Post by bobber »
Had to use pliers to get the baffles out of the Kerkers I had on my '82. Removed the screw, tapped the baffle end with a dead blow hammer then used a large set of channel-lock pliers I had to grasp the baffle end to pull out. After I had out used anti-seize so never had any trouble after.
Some muscle, rubber hammer and PB Blaster spray lube.
cbxpearl
Post by cbxpearl »
okay thanks.... I'll give it a shot ( when the rain stops, hope it's sometime this month)
