Are there any tricks to r&r the regulator?
last426
Post by last426 »
Wow, this baby is tightly above the swingarm with allen head screws and those puppies are way hard to get to. Any cool suggestions would be appreciated (might be a good tool buying opportunity) and I will get the beer the next time you are in San Francisco. By the way, I am not sure that Honda used allens instead of hex heads so they might have been switched. Thanks.
last426
Post by last426 »
Okay, the easiest way I found was to remove the rear brake light switch, remove the rear plastic fender, cut about 1/2 inch off the end off a 5mm allen wrench (these are hardened steel so a hack saw won't touch it -- I used a chop saw), get a 5mm 1/4 inch socket, insert the allen wrench part in there and the rest is obvious. Kim
