exhaust question
cbxtacy
exhaust question
Post by cbxtacy »
I was just looking at my after market exhaust compared to the stock. That includes supertrapp, jardine, D & G, bub, denco. The stock is double wall. You need a certain dia for the collars to fit around. 1 3/8". On the stock head pipe the inside pipe dia is 1 1/8". The aftermarket (except for the Jardine) are 1 3/8 through out. If one were to build an exhaust, would it be better to build it 1 1/8" on the head pipes with a sleeve around the end for to hold the collars? How do breathing characteristics change with larger dia head pipes? I believe it gives more top end at the expense of mid range and bottom end. Is that something you'd want with stock rods?
YOU'RE THE ONE
alimey4u2
ICOA Web Video Director
Post by alimey4u2 »
I think the trick is to keep exhaust gas velocity high but not cause too much restriction...As you know, scavenging is the art & craft of it all. I understand two stroke expansion chamber design but struggle with the nuances of 4 stroke systems :?
Don #6141
Post by Don #6141 »
I'll bet this one makes the most power
http://www.schuele-maschinenbau.de/page ... ik/cbx.htm#
Good pictures of it on pages 3 and 4
It's a 6 into 3 (with #'s 1 and 6, 2 and 5 and 3 and 4 paired up with equal length tubes) into one . . . . all stainless
If you want to start building up something, stay close to that design and I think you'll be happy. You might actually make a buck too - These are no longer available and are going for ~$3500 when you can find a set
It does. Schuele says it produced 120hp on a dyno an otherwise stock motor.
2525
cbxtacy
Post by cbxtacy »
also known as a "tri-Y" in a chevy. I also measured header length. Stock is the shortest at 1'10". I just checked 2 pipes on the D & G and came up with 2'2" and 2'8" for different length tubes.
YOU'RE THE ONE
cbx6ss
Post by cbx6ss »
Looks like its hard to get at the oil filter. But if I had a set it might be worth the hassle.
/r
B
It may be a little hard to see, but my avatar shows the Schüle installed on a motor. The filter is easily accessible through the gap between 3 and 4, however, oil will spill on the headers when you take it off :roll:
Don #6141
Post by Don #6141 »
This guy claims he can get you the Schuele exhausts:
Contact: Jason
6709 La Tijera Blvd. #823
Los Angeles, CA 90045 PH: (310)-668-1601
Price is $2288 for the unpolished pipes - The muffler is about $800 more
The header runs at around 1,500 Euro. At current exchange rate, that is already $2,300.- and then you don't have it here and Jason probably wants to make a profit. Unless Jason is a real philantropist, the $2288.- seem a little low.
