It seems that ignition plate does not have enought space to do adjustment. I am doing dynamic adjustment based on the shop manual and the ignition is in behind but cannot turn the plate. Before I start to modify plate´s screw holes I would like to hear is this common issue with dyna-s plates?
Cheers, piit
Dyna-S ignition adjustment
- piit
- alimey4u2
- ICOA Web Video Director
- piit
Hi and thanks, but the original Honda pulser plate was succesfully installed and ignition "mechanical" adjusted after the primary and cam chains replacing, so that´s not the case now. I never did dynamic adjustment with the original pulser plate because the mechanical style adjustment was ok.
Anyway I grinded the dyna-s plate so much that the dynamic adjustment could be done.
Just came from the test ride and seems to be work ok.
Still wondering this dyna-s plate adjustment and would like to still hear other experiences.
Cheers, piit
Cheers, piit
