GRINDING NOISE
GRINDING NOISE
Hi everyone, took my 79 Z out friday afternoon for its first ride of the year. Eveything was going fine until the bike started making a horrible grinding noise at low revs. It isnt all the time and seems to happen more when pulling away from junctions over taking cars etc. On a 40 mile run it happened about 5 times. The noise seems to be coming from the top end, but is hard to tell when riding ! Started it up this morning ran it for 10 mins not a peep. When it makes the noise it lasts for about 5 seconds and does not affect performance. Any ideas? When it happens it is loud.
Hi Steve,just been out for a gentle ride of about 15 miles. It made the noise again about 3 or 4 times, i was trying to find out where it was coming from with no luck. If it was something serious in the motor woudnt it make the noise all the time? Sods law it has only done it once when pulled over with no helmet on. Because it only lasts for 5 seconds or so coudnt tell where its coming from. The bike starts first time and appears to be charging ok.
- alimey4u2
- ICOA Web Video Director
Merv, Check the alternator cover for excessive heat around the center bearing area, pull the alternator off & have a look at the clutch plates. If there is evidence of "galling"( looks like serrated radial marks) that may be the problem...
As discused over the phone, these intermittent probs are the hardest to find....
Keep us updated, as Steve said, look for the silly easy things first & get them out of the equation.. Then, drop the sump plate & look for fragments..copper/ zinc, aluminium, steel or rubber, as the noise is intermittent & power isn't compromised, it kind of leads away from catastrophic problems...
- ICOA Rally Director
Hi its fixed !! Guys you were right it was the alternator. Just as Larry said there was serrated radial marks on both plates. I swapped them for ones off my restoration bike and now it runs fine. Can i get the serrated plates machined or are they still available from honda? Thanks guys, Larry gonna buy you a drink or two at the rally.
- alimey4u2
Glad I could help Merv but it was a system of elimination by a group/ team effort.....merv 1 wrote:Hi its fixed !! Guys you were right it was the alternator. Just as Larry said there was serrated radial marks on both plates. I swapped them for ones off my restoration bike and now it runs fine. Can i get the serrated plates machined or are they still available from honda? Thanks guys, Larry gonna buy you a drink or two at the rally.
I'm sure they are available Merv, try Honda or David Silver or Louis. If a problem getting them give me a call....
I'm not too sure about machining as there are oil slinger slots, if you did you would have to take up the spring tension with washers, I'm sure someone will advise further....
