spark plugs
spark plugs
What brand of spark plugs should I replace with? What stock number for the spark plugs? What works better, paper air filter or oil soaked filter?
- alimey4u2
- ICOA Web Video Director
Duane, The Canadian model came recommended with
Standard ( "ND" X 24ESR-U, "NGK" DR8ES-L)
Cold climate ( below 41deg F) ( "ND" X 22ESR-U, "NGK" DR7ES)
Extended high speed riding. ("ND" X 27ESR-U, "NGK" DR8ES.)
If you transfer these numbers to other manufacturers they should be OK.
Interestingly the "Splitfire" plug is "theoretically" ideal for the twin fire reversing polarity ignition on the CBX but I have never tried them. The only system it ( Splitfire) could "possibly" show any benefit...
As for filters, "efficiency" is two fold, that is to pass air & that to do it's job of removing airborn contaminants. There is always a tradeoff between the two...
Thanks, John. I thought it was paper inside the wire mesh.
I did not try any rejetting being the "keep it simple stupid" guy that i am. I was getting a lot of blow-by engine oil in the air chamber and filter box resulting in a messed up stock foam filter. I had the K&N kicking around and figured i would try it out.
Terry, did your '79s have the stock pipes when you used the K&N?
- alimey4u2
Not sure Steve, got it out my 1980 Owners Manual, complete with a typo that I edited..415ZR1 wrote:Alimey4u2,
Interesting to note that for '79-'81 US models the non-resistor version of the plugs you listed above are recommended. Wonder if the Canadian gov't has or had stricter regulations concerning RFI? Guess in '82 the US caught up on RFI legislation or Honda just standardized CBX plug selection.
PS. Interesting info on the plug mod.....
Valentine 1, an older model but with some upgrades. Resister plugs solved the problem. Never had the problem on the Busa.EMS wrote:That's interesting. What brand/model radar sniffer do you use, Terry?Terry wrote:Without the resister plugs my radar detector goes off nearly all the time! Have to use them.
