alternator /charging problems
my 79 z is not charging the battery while running,i hve removed the alternator,and the brushes are fine and nothing looks wrong ,is there a way to bench test it ,and if it fine could it be the rectifyer and how do you test these.any awnsers greatfullyrecieved
regards tony
ps otherwize it runs great
regards tony
- alimey4u2
- ICOA Web Video Director
Welcome to the site & club Tony.....
To add to Mikes excellent support & advice, don't forget to check the continuity of the spade connectors ( looks like Mike has covered that.) They are notorious for furring up ( oxidizing.) There may be tell tale signs on the wires, that being, overheated insulation. Is your battery in good condition ?
Please keep us updated on your progress....
- alimey4u2
First thing to check is the continuity between the slip rings (copper rings) on the rotor. The early manuals don't give a specified reading, but the late manuals do. The resistance HAS to be between 3.5 and 4.8 OHM. If it is higher or lower(I've seen both) - the rotor is bad and needs rewound. This is by far the most common failure apart from brushes. The stator test is pretty conclusive, but the reg/rectifier test is useless. You just about have to replace it with a known good one. My bet is the rotor. Replace both bearings and seal while you in there.
- alimey4u2
- CBXRoger
Alternator Clutch
Another thing to check, if the electrical checks don't find a problem, is the mechanical clutch that drives the alternator. Occasionally, the spring will loose its tension or the disks will become worn, and the battery will not be charged.
I had a problem on my '82 CBX when returning from the C2C ride across America. At low engine speeds and cold engine, the battery would be charging. At highway speeds, the battery would start to discharge. When I arrived home and inspected the clutch, I could find nothing apparently amiss.I bought a washer and placed it behind the spring to add additional pressure on the clutch, and the problem was solved.
Roger
Roger
CBX not charging
Hello, new to ICOA and glad to be here! I've got an '82 with the exact same problem. Replaced brushes, rectifer/regulator, new battery, continuity checked all the wiring, still no charging. I took all the readings in the manual and the rotor reads 1 ohm or less, so I'm having it rebuilt. Hope that solves the problem. Only had the bike for a year and haven't even had it out for more than a couple of miles. Runs great...on the battery!! Thanks for all the suggestions, I've been reading all the postings.
- CBXRoger
CBXTony USA,
The other weak link is the red connector under the right side cover. It connects the alternator to the rectifier. Corrosion and resistance will cause it to heat up and melt, as the efficiency of the charging system goes down.
I have had to replace this on both my '82 and '81 CBX'es.
Let us know what you find on your CBX.
Roger
Roger
