Coil Gremlins
Coil Gremlins
Maybe you guys have an idea:
One of my Sixes was running poorly and I found cold headers on 2 and 5. Quick diagnosis showed a sometimes very weak, sometimes non-existing spark on 2 and 5. As I still had a set of new, never installed Accels lying around, I decided to replace the coils. I also invested in six new plugs.
First try, bike runs like a charm. Take it to work for 15 miles, runs excellent in the morning. Park it and when I start it at lunch it runs poorly again. take it home and find headers 2 and 5 cold. Going over all wiring and connections and do some ignition checking, everything seems O.K.
Next thing, is checking the coils and I find the primary winding on coil 2/5 shows zero conductivity. Question: is this just a coincidence or is there something that can make the coil go kaputt?
I really hate electrical stuff. :roll:
cbxtacy
Post by cbxtacy »
Stock ignition or after market ignition? Swap the ignition units around and see if it does it on another set of cylinders? I'm an electronic idiot, that's why I have multiple CBX's. It could get expensive going through coils until you determine what the problem is. But that's better then a 698cc four cylinder CBX with a 120 degree crank.
YOU'RE THE ONE
Stock ignition, George. Only change was going to Accel coils. The one coil is broken now. I tested it out of the bike and it has no conductivity in the primary wiring.
cbx6ss
Coil problem 3,4
Post by cbx6ss »
I think I have a bad 3,4 coil (no spark). I tried the service manual spark test; failed. All three coils come up around 570 ohms. I have eleven volts at each spark unit Can the coils be replaced individually, or must they be as a set?
Anyone have a set of coils for sale?
/r
Brad
Chris
Amazing Poster
Amazing Poster
Re: Coil problem 3,4
Post by Chris »
cbx6ss wrote:I think I have a bad 3,4 coil (no spark). I tried the service manual spark test; failed. All three coils come up around 570 ohms. I have eleven volts at each spark unit Can the coils be replaced individually, or must they be as a set?
/r
Brad
They can be replaced individually. I believe they are still available from Honda and aftermarket. I'll try to find/post a link to an aftermarket later today.
Chris
Amazing Poster
Amazing Poster
Post by Chris »
A couple of possible coil suppliers...........
Aftermarket............
http://cgi.ebay.com/ebaymotors/HONDA-CB ... enameZWD1V
Potentially a good price on a factory one............
http://www.oldbikebarn.com/motorcycle_p ... s&bike=CBX
cbx4evr
Post by cbx4evr »
cbx6ss wrote:Anyone have a set of coils for sale?
Brad
I've got a set of Accels with wires that I won't be using since I sold the CBX.
http://www.cbxman.com/detail.aspx?ID=713
"It's a friggen motorcycle, it's not supposed to be comfortable, quiet or safe. The wind noise is supposed to hurt your ears, the seat should be hard and riding it should make you shit your pants every now and then. "
