Which header gasket is best?
Dynamohum
Post by Dynamohum »
Upon removing the exhaust (after) 43 years I could see that the OEM ring gaskets were a certain kind, one of those shown below. Is one better than the other?
Re: Which header gasket is best?
I prefer the cooper, you can reneeal them and reuse them.
The green ones are quite robust and last forever, however they are a bit thick and can present installation problems until you get them squished, and they don't squish a lot. They tap in place, unlike most copper ones that you must oval a bit to stay in place. There is nothing better than the OEM ones, too bad Honda stopped making them years ago. Another thing we should have stocked up on!
CBX-tras
Post by CBX-tras »
I prefer the copper ones but have used both.
The recess in the head isn't round, "bump-outs" where the studs are. I use a large socket as a tool to insert them.
If yours' are little small, a dab or 2 of RTV will hold them in place until you get the pipe/collar installed.
Dynamohum
Post by Dynamohum »
The combination gasket, two piece collar and star seems a tad overdone doesn’t it? Wutta PITA working alone! And why’d they add a cross over pipe, just to make assembly even harder?
Crossover pipe for mid-range torque.
