Noise with the central stand
Hi everyone, i'm new in this group and i dont really know if this is exactly the right place to ask this.
As the title of this post says when im riding the center stand makes noise when i go over a pothole. Does anyone know what the reason is?
Sorry for my english, im from spain
Honda CBX 1047 pro-link (The Queen)
Suzuki GSXR 1000 k7
Suzuki VStrom 1000 k2
Suzuki GSXR 1000 k7
Re: Noise with the central stand
You'll need to investigate further.
Could be a weak return spring and/or the rubber cushion missing from the exhaust pipe.
(assuming you have a stock exhaust system).
Thanks, yes i have the stock exhaust system. I think it could be the spring as you say but im sure that i dont have the rubber cushion you mention.
Can anyone tell me where i can find it? And it would be perfect if someone could take me a picture of that
Thanks very much
Thanks very much
Suzuki GSXR 1000 k7
Suzuki GSXR 1000 k7
Here you go. The side stand rests on the rubber when it’s up.MagnusXII wrote: Mon Nov 25, 2024 10:25 am Thanks, yes i have the stock exhaust system. I think it could be the spring as you say but im sure that i dont have the rubber cushion you mention.
Thanks very much
Thanks a lot, i have lost that rubber. I'll try to find it, any advice where i can buy it?
Suzuki GSXR 1000 k7
Suzuki GSXR 1000 k7
And what about the central stand? Does it have a rubber like that too?Dynamohum wrote: Mon Nov 25, 2024 2:01 pmHere you go. The side stand rests on the rubber when it’s up.MagnusXII wrote: Mon Nov 25, 2024 10:25 am Thanks, yes i have the stock exhaust system. I think it could be the spring as you say but im sure that i dont have the rubber cushion you mention.
Thanks very much
Suzuki GSXR 1000 k7
Suzuki GSXR 1000 k7
Partzilla has them.
ICOA #6266
1979 Honda CBX
2003 Honda Blackbird
2019 Honda CRF450L
2022 Honda Goldwing
1979 Honda CBX
2019 Honda CRF450L
2022 Honda Goldwing
Sorry I must’ve glossed over the term ‘central’ stand. I’ve only ever heard of it referred to as a center stand. So yes there’s another rubber pad in a metal extension on the underside of the left side muffler. When I ran a 6 into 1 exhaust on my ‘79 the center stand would come in contact with the chain as it rotated beyond where the rubber ‘stop’ was on the OEM exhaust. Excuse the grime underneath, I’m locating an oil leak around the counter sprocket. As for locating the parts, there may be others but Louis is bound to have what you need. He’s in Florida.MagnusXII wrote: Mon Nov 25, 2024 4:37 pmAnd what about the central stand? Does it have a rubber like that too?Dynamohum wrote: Mon Nov 25, 2024 2:01 pmHere you go. The side stand rests on the rubber when it’s up.MagnusXII wrote: Mon Nov 25, 2024 10:25 am Thanks, yes i have the stock exhaust system. I think it could be the spring as you say but im sure that i dont have the rubber cushion you mention.
Thanks very much
https://www.usedcbxparts.com/
Thanks for the information and sorry for the confusion i really wanted to write "center' instead of "central ". Good luck with the oil leak, i wish i could help with that but i dont know where it comes from
I'll ask Louis and lets see if he'll be able to ship it to spain
Suzuki GSXR 1000 k7
Suzuki GSXR 1000 k7
have just asked to my father because it was his bike and he told that the exhaust system arent the stock one. Maybe thats the problem. The side stand doesnt rest on the rubber and the center stand doesnt have even the rubber.
Any advice?
Any advice?
Suzuki GSXR 1000 k7
Suzuki GSXR 1000 k7
That is the center stand rest I see in you photo. If your stand does not hit it when up, then the exhaust is for an early model. The stand stops are different. You can make an extension to the stop so it works with your stand. This is the problem with aftermarket exhausts.
Thanks Dave, it is my fathers bike and he has just given me it. When he changed the exhausts system was a long time ago. Even the internet didn´t work as nowadays. Those were the exhausts he could buy.daves79x wrote: Tue Nov 26, 2024 7:04 am That is the center stand rest I see in you photo. If your stand does not hit it when up, then the exhaust is for an early model. The stand stops are different. You can make an extension to the stop so it works with your stand. This is the problem with aftermarket exhausts.
Let me see how i can solve it because its very annoying the noise while riding.
Thanks a lot
Suzuki GSXR 1000 k7
Suzuki GSXR 1000 k7
BTW, this, ‘Honda CBX 1049 pro-link (The Queen)’ should be 1047 unless it’s been bored two ccs
