kerer 6-2 on 79 cbx
Re: kerer 6-2 on 79 cbx
AshishNJ wrote:Thanks . How do remove the cap from exhaust outlet? I removed the bolt but it is not budging out
The end cap and baffle come out as a single unit, at the same time, together, connected, all at once. After you remove the screw, tap it out from the front or pull it out from the rear.
Tapping the top of the perforated baffle or if you can hook it from the the cap end and pull, the baffle will pop out the end cap and the baffle will follow.
Don't use the attic insulation, it breaks down too quickly.
I had to use copious amounts of Kroil and a slide hammer to get the baffles out of mine.
They did not have the front piece of pipe attached to the baffle.
AshishNJ
Post by AshishNJ »
I am trying everything :) . They are in there for a while and don’t want to leave easy . Not giving up yet. Is the packing I listed in thread available at revzilla any good ?
1979 CBX (faster Red)
1981 CBX Streetfighter
2017 Aprilia Tuono.
AshishNJ wrote:I am trying everything :) . They are in there for a while and don’t want to leave easy . Not giving up yet. Is the packing I listed in thread available at revzilla any good ?
Yes it's fine, most M/C dealers who sell accessories have it, sometimes it's in the dirt bike section of the store.
You may have to resort to the slide hammer technique Steve mentioned! Or the poor mans version, get a long nail or piece of rod, sharpen, then bend the tip at a 90, insert it through the end cap and onto the perforated portion of the baffle, hook the baffle and then clamp a good sized Vicegrip wrench to the rod or nail and hit the wrench with a mallet a couple times .
AshishNJ
Post by AshishNJ »
Thanks for the tip. One is out, next to other one. Left it standing with some wd40 . Hopefully will loosen up
2017 Aprilia Tuono.
AshishNJ
Post by AshishNJ »
how much length of packing should I use ? packing comes in 11x16x1" size. is 16" long or I have to cover entire perforation ? Thanks
2017 Aprilia Tuono.
Crazy Canuck
Post by Crazy Canuck »
Yes I know this is an older post.....please bear with me.
Been a while since surfing the forum and noticed this thread. I'm pretty sure I'm the guy that bought AshishNJ's exhaust and noticed that the pics he uploaded to this thread have disappeared.
I didn't know at the time that the earlier models had different mounts than the prolink models, so bought the system not knowing the difference, (BTW no hard feelings at all Ashish), so I just set in motion a way to mount them to my bike. I used some sheet stainless to fab up some brackets, and mounted them to the passenger foot peg bolts for support.
I tried to snap a similar pic that SIXINOZ posted on page one of this thread and used his here as a side by side comparison....just in case anyone else is buying a Kirker exhaust system....there is a difference.
Forrest Miller :thumupp:
Nice work. Thanks.
There were several versions of the Kerker pipes. The first ones had a steel bracket to mount the mufflers to the footplates. The later versions had a large mount built into the muffler. Yes, there were also lower-angle mufflers for the Pro-Link.
