Rear brake reservoir
Is there a aftermarket rear brake reservoir.?Thanks
Re: Rear brake reservoir
1979 CBX
If you can use a stock one, they are a dime a dozen.
Stock as cbx or ?
Where do I get a dozen :)
Site member tevan or even Louis at usedcbxparts.com
They should be able to fix you up.
Thanks.
From what I’ve seen they appear to be quite scarce.
Al
Al
He does not want the rear master cylinder, just the rear brake fluid reservoir.
- Duffey Lake rd.
