Jon's cbx
Jon
Jon's cbx
Post by Jon »
Hello here is my project 82 cbx.
Its in good condition but hasent run since 2005.
Have clean the carburators and got it started thats it.
Jon
Re: Jon's cbx
Post by Jon »
Removed some parts.
Next up is to remove swingarm and replace it with a dual shocks swing.
Jon
Re: Jon's cbx
Post by Jon »
Have drill out the old upper bolts and replaced them with longer to fit shocks.
Now waiting for new swingarm.
Re: Jon's cbx
Looking good, Jon. Enjoy the ride. Thanks.
Jon
Re: Jon's cbx
Post by Jon »
So the new swingarm came today, but was not as expected. Think i got the wrong cb swing. :sad-roulette:
I can shorten it but looking for a more bolton.
Re: Jon's cbx
…a now the adventure begins.
Can I ask why you’re ditching the monoshock and the rising-rate linkage? The Prolink setup with the stock monoshock offers ~4 inches of rear wheel travel in a rising rate setup, When paired with a decent aftermarket shock like a Progressive/Ikon/YSS/Wilbers, it’s quite good - compliant and comfy over little stuff, very controlled and well damped over bigger stuff. Most any twin-shock setup you graft onto it is going to result in less rear suspension travel.
Is this mostly a style consideration? That’s reason enough, I’m certainly not faulting you for that, but it cant be performance-related, in my opinion.
Re: Jon's cbx
Totally agree with Nils. However, if you must have twin shocks, you have the best swingarm you could possible get already there. Just weld on a set of shock eyes. You can also machine off the Pro-Link linkage mounts for using a wider rear tire.
bikeymikey748
Re: Jon's cbx
Post by bikeymikey748 »
Jon, impressed with the excellent condition of your bike. I mean, look at that exhaust!
Jon wrote:
Sat Feb 19, 2022 6:00 pm
I think you might find that any swing arm of more recent manufacture will the reflect the trend that factories took of increased length.
Jeg må berømme deg for engelsken din, den er utmerket.
Best of luck with your mods.
Jon
Re: Jon's cbx
Post by Jon »
Exhaust is aftermarket. I wasnt any good at school so my english still sucks :no
aahrens1
Re: Jon's cbx
Post by aahrens1 »
Hi Jon
Check the Yamaha XJR 1300 swingarm for your project. I had no big issues with it.
Best design has the latest model RP19
https://photos.app.goo.gl/RzRxt2dUvP42Nsdx6
https://photos.app.goo.gl/KBat3UT6WqED62hi9
Regards
Andreas
Re: Jon's cbx
I have one of these left, a braced ZRX modified to fit he CBX.
Re: Jon's cbx
Again - what do you think is wrong with the stock swingarm?
Re: Jon's cbx
daves79x wrote:
Thu Feb 24, 2022 6:42 am
Nothing wrong with them they are sturdy but heavy as hell, a lot of unsprung weight going on there, most modern swingarms are aluminum for a reason and have better axle adjusters and adjustment, like the eccentrics on the ZRX I posted.
If none of that is a concern I’d do what Dave suggested, it’s a proven and easy modification.
Re: Jon's cbx
Jeff - he already has an aluminum swingarm - it's a Pro-Link. Nothing better than that to weld shock eyes onto and it already bolts on.
Re: Jon's cbx
daves79x wrote:
Fri Feb 25, 2022 6:57 am
Yes but like I mentioned, most the modern swingarms have eccentric adjusters, makes it a breeze to drop your rear wheel, and the eccentrics allow up and down and back and forth adjustments.
Return to “Project Threads”
