Ottonero
Re: Ottonero
That is a great build !
1979 CBX (faster Red)
1981 CBX Streetfighter
2017 Aprilia Tuono.
2017 Aprilia Tuono.
Re: Ottonero
I have seen this on a couple forums.
Is it in fact a real motorcycle or just a model for display?
Should have a mock-up of Freddie standing beside it.
- shiskowd
Re: Ottonero
I would suggest that this bike only exists inside a computer...
- Amazing Poster
Re: Ottonero
It would not comply with any of our historic racing rules. Flat side carbs were from a later period and the modern brakes and front end would not pass scrutineering.
I'm curious about what appears to be a central alloy tank or box. Does anybody know its purpose? Fuel, oil or electrics?
- cross
Re: Ottonero
Looks like it's a remote oil tank, if you follow oil hoses. Oil pan seems to have been removed, oil cooler hoses are both connecting to the left side, next to each other.Warwick Biggs wrote: ↑Tue Aug 25, 2020 2:42 amIt would not comply with any of our historic racing rules. Flat side carbs were from a later period and the modern brakes and front end would not pass scrutineering.
Clutch cover is different with clutch cable connecting to the bottom right instead of the top.
Sasha
'82 Honda CBX
'99 Triumph TBS
'01 Honda Valkyrie
'82 Honda CBX
'99 Triumph TBS
'01 Honda Valkyrie
Re: Ottonero
If you remove the oil pan and have a dry sump, you would need a totally different oil pump. The problem then is, how to feed oil pressure to the crank bearings. I am not saying he didn't do it, but it is easier to do in a virtual reality image than in real life.
