- Syscrush
Wow Mike, that's beautiful work!
But you just made me feel twice as bad... What I did today was order superbike 7/8" bars because the CBX controls won't properly fit my sessy Pro Taper bars.
- 80 cbx dude #6216
- cbxmel
That is superb Mike. Well done.
Mel #1876
Mel #1876
Bikes since 1960,BMW R27,Calthorpe 350 twin port, 50cc Maserati,C110,S90,CB92,CB77 webco 350 racekit,C72,CB450,TS125,GT380,GT750x2,Harley 45,Ariel Sq4,Vincent Rapide,NorVin shadow,GPZ750turbo,GSXR1100H,FJ1100,RC30,Moto-Martin cbx x4,CBX specials x3,79cbx x 20 & GL1500
Mike, i like the look especially with the blacked-out headlight ring.
Steve:
when you say, one side more than the other, are you talking intake vs exhaust or left vs right side of cams?
Took delivery of a new set of Sankei 6 into 2 pipes & i'm taking the day off work tomorrow & will be fitting them
Steve: The exhaust valves always tighten up quicker than the intakes, which is why they, especially, should be kept on the loose side. More heat there I suppose.
Thanks for the replies, Gents.
It was 10 exhaust and 1 intake that needed adjusting.
- wyly
Count me in!NobleHops wrote:asacuta wrote:Like I've said before: it amazes me the work people put into their CBXs. Impressive.
What you guys said. Spool it up Mike, I'll help organize a group buy if you can make these in quantity! Looks gorgeous.
- Syscrush
OK, the 7/8" bars are GONE! For those of you who like 1-1/8" bars, you might like to know that LSL makes a Superbike bend Fatbar.Syscrush wrote:But you just made me feel twice as bad... What I did today was order superbike 7/8" bars because the CBX controls won't properly fit my sessy Pro Taper bars.
- asacuta
Took the 81 CBX out of winter hibernation today. The old girl was a little stiff until I got her out on the highway. Amazing a bike so old still runs so well. It looks like I'm starting to get an oil leak around the output shaft. I imagine there's not much I can do unless I'm willing to crack the case and change the seal, which I'm not.
Al
Al:
I may face the same problem. Just saw an oil spot under the bike right there today. There is a way to put a seal in without splitting the cases. It's not the perfect way to do it, but several guys have done the repair and report O.K. results!
- asacuta
So where is this miracle repair described? If no one knows off the top of their head, I'll try a search.
Al
Basically, you have to cut out the old seal and then install the new seal after you trim the lip, that sits in the grove in the case, off. I am not sure that there is a detailed description (with pics) here.
