Stainless Brake Lines for The X: Great Sourcing Alternative
- Mike Barone #123
i think i have a solution that might help members on sourcing stainless lines so i am going to post it rather than wait for the question
if you have neat solution on any cbx matter ......pleassssssssssssssse post it vs waiting for the q. it helps us all and increases the size of the icoa tech help library
bottom line: check your phone book yellow pages for light aircraft parts suppliers in your area most of which have braided line and all the various fittings.
call ahead with what you need and ask if they will cut the line for you which most will so you end up with lines exactly the length you want/need and with them cutting them will avoid frayed braiding if your hacksaw blade is not quite up to the job
they also might have longer master cylinder bolt if you want to run both lines from there vs going into the junction box with one line. take your cbx master cylinder bolt with you to verify the threading with their bolts.
the fittings at the light aircraft shop i went to were brass, i think, and of superior quality which one expects when buying aircraft quality parts
cost was less than $100 and i got exactly what i wanted
sooooo....i took the old lines in, they cut the new lines for me..... plus gave me a booklet on prep/installation.... and in 10 minutes i was on my way.
mike
mike
Last edited by Mike Barone #123 on Mon Dec 10, 2007 9:21 am, edited 2 times in total.
- jt
SS Brake line info
Good post Mike,
I had seen Tom Neimeyer set up he did for his 79X and he showed me how easy it was to do. You can also find or have ordered what you need from a good Automotive Speed shop also. I ordered mine online from American Street Rod http://www.amstreetrod.com/catalog.html . They supply Earl's Performance fittings. I am going to run both lines from the m/c down to a set of rebuilt dual piston calipers. Cost for parts was around $70. for 6' of SS line and four banjo fittings. I bought extra line to eventually do the rear brake line.
JT In Texas
the mirror every mornin'.
Just to keep this one up front. Could prove useful to a number of us.
I bought Spiegler and Fischer Stainless steel braided brake lines in Germany in the past for $105.00 the complete set front and rear. Due to the angle of the banjo fitting, the Prolink lines differ slightly from the early ones although they can both fit either application. I had two sets left over and tried to sell them on ebay for that price and nobody wanted them.
- spencer
Re:
Do you still have those brake line sets for sale? Are they covered with black vinyl? I am looking for a set of stainless braided lines for my '79, but I would prefer that they be black.EMS wrote:I bought Spiegler and Fischer Stainless steel braided brake lines in Germany in the past for $105.00 the complete set front and rear. Due to the angle of the banjo fitting, the Prolink lines differ slightly from the early ones although they can both fit either application. I had two sets left over and tried to sell them on ebay for that price and nobody wanted them.
Spencer
SCH Rochester, MN
- ICOA Rally Director
Re: Stainless Brake Lines for The X: Great Sourcing Alterna
Pssttt.... Spence.... heat shrink tubing.
- spencer
Yes, I thought about that. If you use shrink tubing big enough to fit over the banjo fittings, it might not shrink down enough to be tight. Also, I don't think shrink tubing is as durable as vinyl. I'm not discounting it completely. What I really would like to get is stainless steel, vinyl coat, and with the other protective rubber fittings which are on stock lines. They would look like the lines Tims has for $195 but stainless steel. Like these:Rick Pope wrote:Pssttt.... Spence.... heat shrink tubing.
SCH Rochester, MN
I've made several sets of braided lines from a kit my brother has. I don't know his supplier, but he buys fittings and line seperately and makes each line to fit. The ends are screwed together, so you can turn the banjo to where it doesn't try to twist the line. You also can slip something like fuel line over the braided during assembly for that stock appearance.
