This curated list of threads might help researchers with frequently asked questions. Suggestions for additions are most welcome.
Big Brake for 79-80 "Twin-shock" bikes: viewtopic.php?f=50&t=12491
Upgraded Master cylinder options: viewtopic.php?f=50&t=12271
Master cylinder leaking between the reservoir and the body? viewtopic.php?f=50&t=11819
Braided steel brake line options: viewtopic.php?f=50&t=11832
Removing stuck caliper pistons, part 1: viewtopic.php?f=50&t=11875
Converting 79/80 brakes to two-piston calipers: viewtopic.php?f=50&t=8195
Brake bleeding tips: viewtopic.php?f=50&t=11121
Brake dragging tips: viewtopic.php?f=50&t=11121
NLA rear reservoir hose alternatives: viewtopic.php?f=50&t=10058
Extracting the rear master cylinder piston: viewtopic.php?f=50&t=8947
1980 rear brake caliper piston size "gotcha": viewtopic.php?f=50&t=8363
Adjusting the height of the rear brake lever: viewtopic.php?f=50&t=6887
Regrinding brake disks: viewtopic.php?f=5&t=7545
Thread Index - Brakes - START HERE
Re: Thread Index - Brakes - START HERE
Again, thanks for putting these together in one thread.
Steve, if you (anyone) find yourself in your chair and want to nominate other threads that ought to be included, just post them in thread and I shall add them to that post, Consider that a first draft that we should all feel free to improve. I’ll continue in other areas.
