Engine oil pressure gauge
Posted: Mon Mar 30, 2009 10:30 am
by alimey4u2
Bought this on E-bay from TAS Classic Motorsports "Serving the elderly for over a decade" ( felt quite at home
Nice quality item & they sent me American candy in the box too....
Ps I have no affiliation with TAS Classic Motorsports, real or suggested. Just thought I would share...
Posted: Mon Mar 30, 2009 10:57 am
by cbxtacy
and if you're ever stranded in the Sahara, you can pull out the little black rubber plug and drink the vodka they fill it up with (liquid filled) for life giving nourishment. That is what they fill liquid filled guages with, isn't it?
Posted: Mon Mar 30, 2009 11:00 am
by alimey4u2
cbxtacy wrote:and if you're ever stranded in the Sahara, you can pull out the little black rubber plug and drink the vodka they fill it up with (liquid filled) for life giving nourishment. That is what they fill liquid filled guages with, isn't it?
Cheap ones are filled with Glycerine & expensive ones with Silicone George, both will give you the sh!ts...
Posted: Tue Mar 31, 2009 1:47 am
I am still trying to find a spot to mount the gauge near the instrument pods, connecting to the fitting with a metal line.
Posted: Tue Mar 31, 2009 1:53 am
by Terry
So, how's that going?
Re: Engine oil pressure gauge
Posted: Fri May 20, 2022 12:02 pm
by tomdsew
Hi do you have a link for it I would like one for mine
Posted: Fri May 20, 2022 12:13 pm
That’s a 13 year old post, Tom, I think you may need to start from scratch.
Posted: Fri May 20, 2022 12:16 pm
by tomdsew
Just checked tas have gone now does anyone else know where I can source one
I’ve looked everywhere I can think of
Posted: Fri May 20, 2022 12:46 pm
by CBX-tras
I used a VDO instrument when I built Randakk's 1100F a few years ago. The mounting, line connections and any machining, you'll have to DIY.
Posted: Fri May 20, 2022 12:57 pm
by CBX-tras
Here's that same gauge (only, no fittings) from the first post, from Amazon here in the US,:
https://www.amazon.com/CWB00060-Liquid- ... B00TYY8L2M
Posted: Fri May 20, 2022 7:34 pm
by JoeInTUS
That gauge only goes to 60 psi. A higher reading gauge is needed since the spec for oil pressure is 64-71 psi at 4000 rpm.
Posted: Sat May 21, 2022 9:10 am
by CBX-tras
My bad.
Posted: Sat May 21, 2022 9:36 am
by hondaman160mph
Posted: Wed Jan 18, 2023 3:47 pm
by Duffey Lake rd.
I got my oil pressure gauge fittings from Tim's CBX.
I just bought that gauge recently in silver and it works at idle, but then it goes off the scale when I rev it.
The glass face on off-scale gauges can shatter.
Marshall also has a 100psi gauge so I swapped out my 60psi for it.
https://www.amazon.ca/Marshall-Instrume ... 901&sr=8-6
-Scott
